Keith Williams
Been flying my RV6 with slosh since 1999. I built the plane 1989-99 and followed Van's directions to paint slosh over prosealed seams and to slosh the back cover. Now I am considering selling it and have started a slosh removal project.
I read the most promising looking threads under a slosh search here. Also wrote to Van's asking for recommendations. Got a note from Ken that Van's has no recommendations or materials for doing a slosh removal project. He said that it is such a bad job that I should just make new tanks. With these old (not pre-drilled) tanks I do not want to do that. Called Van's tech support and was lucky enough to have Scott pick up. He set me up with the covers for re-closing the back plate, new pro-seal, rivets, and the new pick-up tubes. I will also be doing the other tank service bulletins.
Have opened up the left tank by removing the access cover at the base and using a 5" hole saw to open up the outer four bays. There is a place where the slosh is coming loose on the outer rib by fuel filler. The rest of the slosh is solid - no cracks, etc. (Frankly, if I were keeping the plane I would continue flying it after addressing the small area where it is peeling. In view of the service bulletin, I am going to remove the slosh.)
My plan is to go at it with MEK, a Hobby Air respirator, gloves, Scotch Brite and stiff brushes.
My main question is what to do after I get the slosh off. I expect the process to do major damage to the existing pro-seal. Should I try to work in new proseal on all the seams or would it be OK to use a brush-able form of pro-seal or perhaps PR1005 on the seams?
Any tips from those who have been there will be appreciated.
I was really disappointed with Ken's response. Do any of you recall if Van's has some some guidance on this - maybe an RVator article (I have seen the Evans write-up referred to in the threads)?
