some theories, but no 'fixes'
Mike, I can't quite tell the age of your -6, was it built in 2000, or 2007?
in any case....
....this internal 'crazing' I have experienced to varying degrees; much more with polycarbonate than acrylic.
some theories;
If your bird is 10+ years old, is stored outside or in hi temps, then a good part of the condition is likely just 'age'. The resins harden, UV changes the properties etc.
If the canopy was pulled into position with any force, then that can show up as stress risers later...you'll rarely see this on a flat, non-stressed area.
The edge of the acrylic is much more prone to attack than the faces, so if some type of sealant was used at the base of the windscreen, it can start stresses or even full-on mechanical cracking at the edge, that slowly migrates upward.
I hate to say it, but you might be looking at a new windshield, ( I find this kind of thing nearly intolerable when the sun is at just the 'wrong' angle.)
again, seek out other professional help as suggested by others.
good luck!
