6A legs will not work. You will need a new eng. mount, and legs. Also you might need to beef up the last fuselage frame with a doubler, per the plans. The area around where the new tailwheel will mount is different in the -6 than it is in the -6A.
Suggest you do a search on the VAF site, as this has been discussed thoroughly over the years.
Standby: Experts will check in shortly. I am not an expert. And YMMV.
