Tom Martin
One of the problems with a tail wheel is how to tie it down. Usually you wrap the rope around the upright spindle, around the tail fork, or combinations of both.
I couple of years ago I welded a small "loop" on the back of the steering arm and it has proven to be very handy. Wayne Hadath, The Rocket Tail Link steering arm, has improved on my idea and made it a standard on all new steering arms.
As an ADDED bonus, if you are the kind of guy that can build an airplane, you can make a push/pull handle to move your airplane around WITHOUT PUSHING ON THE TAIL!!!
I call it a hockey stick tow bar. Weld or bolt a stub to the bottom. I cut a little notch in the bolt that engages the loop on the steering arm
This thread is sponsored by Rivet the Lab and her friend Buck the stray cat
contact Vince Frazier at Screaming Eagle or Wayne Hadath at Just Plane Parts
I feel obligated to admit that I was given a steering arm for the idea.
