Old 05-24-2013, 06:28 AM
avi8tor50 avi8tor50 is offline
Default Magneto Overhaul?
Hey Everybody!
I now have 470 hrs on my slick mags and four years (came new with new engine). I have read many older threads regarding mag maintenance, IRAN, overhaul, replacement, etc. Was wondering if folks would be kind enough to provide opinions regarding best way go. I plan to at the least do an IRAN when I hit 500 hrs but was wondering if most people just went ahead and actually did an overhaul. I have watched Mike Busch"s EAA presentation of mag maintenance and am aware of his recommendation for IRAN as opposed to true overhaul.
Was also wondering if folks would comment on which shop they used to have either an IRAN or overhaul and what the cost was per mag.
As always thanks for your advice!
Peter K
Moving back to Charlotte NC this July!
9A-470 hrs
Old 05-24-2013, 06:44 AM
WA85 WA85 is offline
If you have Slick 4300 Series magnetos, there is a 500 hour inspection. The manual that covers this is L-1363 Rev F or later. The inspection requires the use of special tools available from Slick (about $350). The breaker points typically show signs of pitting at 500 hrs, so plan on $50 a piece for new ones.
Old 05-24-2013, 08:48 AM
Kubi Kubi is offline
Had to do the same thing two years ago. I removed the Magneto, sold it and installed a PMag. Meanwhile the second PMag running.
Much smoooooother!
Old 05-24-2013, 01:14 PM
9GT's Avatar
9GT 9GT is offline
I had my 4300 series magnetos inspected and repaired by these folks: http://www.aircraftmagnetoservice.net/
Very honest folks to deal with and a fast turnaround. IIRC, mine came in under $800 for both and a bunch of parts in addition to points were replaced.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2018
Old 05-24-2013, 03:27 PM
krwalsh krwalsh is offline
Default Aircraft Magneto Service
Second for Aircraft Magneto Service. They do great work, and do it quickly.
I have an LSE on one side, and a Slick on the other. When I burn thru both of the mags I have (1000 hours from now) you can bet neither will be rebuilt and I'll be buying a PMAG.
Kevin R. Walsh
Cozy Mk-IV
Old 05-24-2013, 04:38 PM
Darin Watson Darin Watson is offline
Default Mag O/H vs PMag
Sorry if this is thread drift, but what are the O/H requirements, if any for PMags?
Regards,
Darin
C-GULF RV-7 located in Calgary, AB
Old 05-24-2013, 05:52 PM
did both of my slicks this month at lantana. $375 /mag flat rate IRAN. a bunch of parts replaced including the points.
TURBO YES =VAF= Payed Jan2018
RV6-A 4,995 hrs, R-44 1,500 hrs, Helicycle 280 hrs, gyro sold,35,000 miles flown in 2015
