I just stumbled into the issue of where to located the front seat hinge on the floor. I have read some threads about this - locating the hinge aft is good for leg room and solves the issue of the top of the front seat almost passing under the seat support, but it causes interference with the aft stick.
Someone posted that the stick interference can be solved with purchase of an RV-4 aft stick (is bent) and clipping it some - planning on doing this.
Any other tips from you vertically gifted folks?
