Old 07-15-2019, 11:21 AM
Lizard Lips Lizard Lips is offline
Default IO-390 Expansion Plug Removal
I have just received and mounted a Lycoming IO-390 on my RV-14. Maybe I am not understanding all that I am reading, but one source says the Expansion Plug must be removed for constant speed props. That's all they say. Another source also says the expansion plug must be removed AND another expansion plug installed behind the "oil valve". If this is true where can I purchase this phantom expansion plug and how can it be inserted behind the oil valve?
I'm still trying to remove the outer expansion plug with no luck at all. Per VAF thread I have drilled a 1/4" hole in the plug, but where do I go from there? Tried inserting a Phillips screwdriver in the hole and prying it out but it won't budge. Any suggestions? I'm stuck!
Joe
Longview, Texas
RV-14A Fuse and Wings ~80% Complete
Arion Lightning LS-1 Flying regularly
2019 Dues Paid
Old 07-15-2019, 11:27 AM
jrs14855 jrs14855 is offline
Default Plug
The front plug is similar to the expansion plugs on automotive engines. You need to partially collapse the plug, then it will pop right out. Take a piece of steel bar 3/4 or so in diameter. Round the edges slightly. Hold the bar on the center of the plug and strike it with a hammer until the plug is "dished" in the opposite direction.
There is lots of info on the rear plug, you just have to search for it.
Old 07-15-2019, 11:42 AM
Nova RV Nova RV is offline
Drill hole
Auto body slide hammer
No need to do anything about a rear plug, it's ready to go when you remove front plug
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP, B-1900, A319/320, B-757/767, B-737, Flight Engineer-Turbojet
RV-14A kit # 140243 (flying as of 11/18)
VAF 2018 and 2019 paid
www.mykitlog.com/chrismoon/
Old 07-15-2019, 12:28 PM
FANTASTIC !!!!!!! A few licks with a 2-lb sledge hammer and it popped right out. You just gotta get its attention first! I really appreciate all the help I get from you guys. Thanks a bunch. :
Joe
Longview, Texas
RV-14A Fuse and Wings 80%
Arion Lightning LS-1 flying regularly
2019 Dues paid
Old 11-15-2019, 07:25 AM
Stockmanreef Stockmanreef is offline
I take it that I don't need to drill any holes first. Just get the plug to invert.
ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14a (serial number 140073)
N73XP (at least that # reserved now)
