Old 09-19-2013, 02:26 PM
HeliCooper HeliCooper is offline
If you are having issues gaining access or editing the spreadsheets please leave a comment in this thread and I will solve the problem. Thanks
Common traps and mistakes:https://docs.google.com/spreadsheet/...FE&usp=sharing
Inventory sheets:https://docs.google.com/spreadsheet/...Xc&usp=sharing
All inventory lists that I have available are on the above link. Please see the tabs towards the bottom of the page to switch between different kits.
Thank you to user jswareiv for the empennage kit, user Marabou for the wing kit, and user GeraldC for bringing the wing kit spread sheet to my attention.
Last edited by HeliCooper : 12-06-2014 at 03:59 PM. Reason: On going process, will be many edits
Old 09-19-2013, 03:14 PM
Mike S Mike S is online now
Originally Posted by HeliCooper View Post
If we can get a moderator to sticky the link at the top of the RV14 forum it should be an easy find for everyone.
Done, great idea by the way.
Old 09-20-2013, 04:16 PM
Feel free to start populating this guys. I don't have my empennage kit yet so unfortunately I have nothing else to contribute at this point.
Thanks Mike for getting this...um stuck.
Old 09-21-2013, 09:24 PM
Icarus Icarus is offline
Default Thanks
Great idea! As a first time builder (kits not even in the mail yet) I would reallllyyy not learn the hard way EVERY time!
Cheers
Paul M.
Washington DC
Former Airport Bum
RV-4 / PA28-180
Old 03-21-2018, 08:37 PM
HSANTIBANEZ HSANTIBANEZ is offline
Cheers
Were is the roll trim installation?
Hernán Santibáñez
Valparaíso, Chile
RV-7 TMX-IO-360 G3X and VPX Flying over Chile
2018 Dues Paid
Old 03-21-2018, 08:51 PM
mturnerb mturnerb is offline
Plans are here: http://vansaircraft.com/pdf/revisions/RV-10-14_OP38.pdf. Aileron trim is installed in right wing. If you're talking about autopilot servo, also installed in right wing, Garmin version here: http://vansaircraft.com/pdf/revision...4/RV-14_56.pdf
You can order the kit directly from Van's - look for "EA 10 Kit"
I just did this kit - photos in my blog (see signature).
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 09-24-2013, 03:00 AM
Debovsky's Avatar
Debovsky Debovsky is offline
I've broken the ice. I'm quite literate with Office products for years but not with "online" services so I'm not sure if what I've done is okay. Since the page was blank with no headers, I took the liberty of naming these as I think is appropriate and consistent with what you have suggested in the first place.
I look forward to see inputs from other contributors. !!
Marc R. Beauvais
S/N #140070
50% airframe done
C-FOOT (reserved)
2018 due paid
http://www.mykitlog.com/Debovsky/
" Resistance, is futile "
Old 09-28-2013, 02:48 PM
Thank you Marc for getting us going. The idea of adding VAF reference links is perfect! I only changed one thing. I added the Kit before your page numbers. This will help with sorting later down the road when we have Empennage, Fuselage, and Finishing kits all going on as well.
Old 09-24-2013, 12:35 PM
jerry sparks jerry sparks is offline
Thanks for sharing looks like a great idea Jerry
Old 09-24-2013, 01:15 PM
Tom023 Tom023 is offline
Default Excellent!
Marc, thanks for making the first entries! My wing kit sits on the floor as I finish getting the shop ready but I have already marked up my instructions with your comments. While the trailblazers found out the hard way, the rest that follow really appreciate documentation of these areas to avoid the same costly mistakes. I'm sure I'll make many but knowing about the landmines ahead of time certainly is the best way to avoid them.
And thank you Jim for setting up the spreadsheet!
RV14A #140083
Down to last 5%.
2018 Donation
