everyone should smoke!
[email protected]
Smoke -ON-
click on the image
4-pipe exhaust with injectors in 3 and 4.
I have a bit of a pieced together system... an old tank and pump from Smokingplanes, smoke injectors and a needle valve from Smoke System Helper, hose from NAPA, fittings and such from ACS, SS lines from VANS, and most excellent quick Jiffy-tite disconnect push lock fittings from JEGS...
here is the basic layout in the baggage compartment:
FSOVKI2e
after testing the setup I removed the baggage pan to layout structural support:
back together:
here are the injectors:
Fun :)
Oil and oxygen
Stephen,
Nice smoke generation. I noticed your set up and that you have the Oxygen bottle really close to the oil tank......not a good scenario if you have a leak, fire etc. ?? Nice looking clean installation.
Marc
Stephen,
Great installation. Marvin is a great fellow to work with and has a lot of expertise on these systems.
I too have mine plumbed into the 3 and 4 exhaust system on my 4 pipe Vetterman exhaust. It works fine.
See ya at Oshkosh. I hope.
Jack
