Old 02-13-2018, 06:51 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Buying an Avidyne IFD540/440
For those of you who bought an Avidyne IFD540/440, where did you buy it? Did it come with the tray/installation kit or was that separate? Did anybody take advantage of the GNS-430(W)/530(W) trade in stuff? If you did, how did that work? Would you do it again the same way?
Thanks!
Dan Langhout
2018 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
380 hours and counting . . . .
Now based at Moontown (3M5)
Old 02-13-2018, 07:55 PM
jakej jakej is offline
Yes the tray is included however, like all? IFR units, the Gps antenna is not. the manual has a list of which other manufacturers antennas can be used as well. You existing one could be eligible.
As for the great 'trade in' deal - I don't know how many have done that, I just replaced my GX60 with the IFD440.
BTW - the free APPs are great & by using iPad the 440 can be displayed on a much bigger screen, more cost effective for some this way
Old 02-14-2018, 08:06 AM
Thanks! Where did you buy yours?
Dan Langhout
Old 02-14-2018, 11:10 AM
Bugsy's Avatar
Bugsy Bugsy is offline
Default just did the trade in
I just did the trade in of my 430W for an IFD440 in early December. I did it directly with Avidyne, email me and I can give you contact info if you want (paulgardetto@gmail.com).
Would I do it again, Absolutely!!
I going to fly right now with my new avidyne and play with all these neat features.
Paul 'Bugsy' Gardetto, Col, USAF (ret)
Milwaukee, Wisconsin (Timmerman Field)
N377KG - Flying (250 hrs)
RV-7A, Aerosport O-360, WW200RV
Advanced Flight 5400
Avidyne IFD440
Paint by planeschemer.com
Old 02-14-2018, 01:42 PM
fred mann fred mann is offline
I just did the trade as well. Sent my 430W to Stein and he sent me a new Avidyne 440 using the existing 430 tray and backplate. Just remember to take a picture of the setting/configure page of your existing 430 to transfer that info to your new Avidyne (which I forgot to do!). I do like this Avidyne unit so far.
Fred M.
RV-7 flying
RV-6. Sold 2006
Old 02-14-2018, 03:57 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
I bought my IFD540 from Stein (actually Christer - I didn't see Stein there when I picked it up). The installation kit was extra since it was a new install; if you are replacing a 430/530 you wouldn't need it.
I'd totally do it the same way again.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 02-15-2018, 03:58 AM
amekler amekler is offline
I sold my 430w on eBay and got $1000 more than Avidyne trade in quote and purchased my 440 from Advanced Flight Systems with my settings all set up.
Avidyne avertises plug and play but if you have have a 12v system you need to have the circuit breakers for the comm 10 amps and for the gps 7.5 amps
so I had to upgrade those. It needs more power than the 430.
I.m very satisfied with it.
Alan
N668G RV10
Old 02-15-2018, 06:37 AM
From Avidyne
Old 02-23-2018, 09:36 PM
tim2542 tim2542 is offline
Looking at this also, right now my best qoute is $4500 + my trade. My question, do I really want to spend another $850 for the BT option? What do you get for that money besides zapping a flight plan from your iPad over to the Navigator? And can it be added later?
Tnx, Tim Andres
Old 02-23-2018, 10:10 PM
Default IMHO, Yes and Yes
Tnx, Tim Andres
With BT and WiFi, you can also use the IFD100 iPad app to control all aspects of the IFD440 - with a larger screen to boot. It is my understanding that all IFD's have the BT/WiFi hardware. The $850 option is to enable the hardware via a software key of some sort (believe it is tied to your N-number). Should be able to add any time you want - but you should probably check with Avidyne.
Dan Langhout
