Old 02-07-2018, 07:08 AM
Ezburton Ezburton is offline
Default G3X Touch GPS Antenna Length
Hi all,
I am finishing up the install of a dual G3X Touch and go to the point of routing the GPS antenna which plugs into the back of the display (GA-26C). The cable for the antenna is about 10ft long and I need about 1ft.
Has anyone cut out the middle 9 feet and spliced it back together? I imagine the wires are pretty small and they and the shields would need to be soldered. I hate to have a big coil of wire hanging around behind the panel.
Don
Old 02-07-2018, 07:24 AM
Electrogunner Electrogunner is offline
Default Coax
Just cut to length and crimp on a new connector. Stein has the crimper and connectors and a video on how to install connector.
Donation Made For 2017
RV10 N620RV
IO540 C4B5
Whirlwind 375RV
Garmin G900X
Final assembly
Old 02-07-2018, 08:01 AM
Walt's Avatar
Walt Walt is offline
I would just coil it up, installing those mini coax connectors is "challenging".
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 02-07-2018, 09:48 AM
Shawn25854 Shawn25854 is offline
Before you cut it be sure it doesn't need to be a minimal length for a proper signal.
Shawn
Old 02-07-2018, 01:56 PM
Rick_A's Avatar
Rick_A Rick_A is offline
If itís challenging for Walt, that means it next to impossible for us mere mortals.
Rick Aronow,
A&P, iRMT
Flying 7A Slider;
RV-12 (ELSA, Dual G3X), SOLD
Highland Village,TX
Old 02-07-2018, 03:48 PM
redbaron redbaron is offline
Default Cable
Garmin manual says to not cut the cable but coil it. Impedence issue
Old 02-07-2018, 04:00 PM
Originally Posted by redbaron View Post
Impedence issue
This is technically incorrect. The impedance of coaxial cable is independent of its length.
Old 02-07-2018, 07:41 PM
I couldn't find anything about not cutting the antenna length in the install manual, just a lot about where to locate it (Section 22.1). Where did you see that?
I was thinking of reusing the mini coax connector... just cut the middle out of the cable and solder all the wires together and heat shrinking the whole thing.
Still not convinced this is an awful idea... but maybe it is something I can try after I get the plane put back together and back in the air.
db
Old 02-07-2018, 08:13 PM
rapid_ascent rapid_ascent is offline
I don't think its a good idea to cut and re-solder. The impedance of the coax depends on have a continuous braid around the center conductor and the diameter of the center conductor. Both would have to be soldered and both would most likely be different than a unmodified section of coax. It would be nearly impossible to do and not effect the impedance. You will then create a discontinuity and the performance will be degraded.
As Bob mentioned the impedance isn't a function of the length of the cable. It has more to do with the relationship between the center conductor, the dielectric and the braid. However, the loss is a function of the length of the cable. I'm not sure if this is important or not in this application, only Garmin would know. If you were to shorten the cable it would be best to crimp on a new connector. With these smaller coax cables, and I haven't seen this specific cable this can be difficult to do correctly. I would suggest you just coil the coax as others have suggested since it will be hidden anyway.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Rolled the Fuselage
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 02-07-2018, 08:15 PM
db
This is a horrible idea. Even good connectors introduce some loss.
Edit: see Ray’s post for a more thourough explanation.
