RedRaider94
I have been doing some work on the EFIS systems and created a new problem that I am struggling to diagnose. When I turn on the Nav lights, both light up well on the wings. When I then turn on the landing lights, they come on as normal on the left wing along with the red light staying bright, but on the right wing, the green light dims to almost not noticeable and the landing light is on but not as bright as normal.
If I turn any of the lights on in isolation but when I turn on the nav lights in addition, the left wing is fine but the right wing has dimmer lights.
I also notice on the g meter that is backlit, when I flip the mag light, the backlight dims like it is no getting as much power. It doesn?t dim when I turn on the landing or taxi lights.
This is all with just battery power.
Any thoughts on what I might have messed up or ideas on what could be happening so I can try to eliminate potential causes to figure out the actual issue?
Thanks!
Thanks!
