Old 06-18-2018, 02:19 PM
Zazoos Zazoos is offline
Default Fuel Pump Fitting
Lycoming 0320 Mechanical Fuel Pump Fitting
Two questions.
1. The blue restricted port that goes to the transducer for the fuel pressure. The thread type is 5/16-24. It looks like and AN-2 type of fitting but I don't know. Basically I need a hose and fitting to attach to this port.
2. Should this fitting have an o-ring where it connects to the fuel pump like the inlet port?
Thank you,
Trent Flemming
Hallsville, TX
Purchased RV6 - Slider Project
Currently flying X-Air LSA and Powered Parachute
Dues Paid 10/2018
Old 06-18-2018, 02:27 PM
lr172 lr172 is offline
Two questions.
Thank you,
fuel pump fitttings are ORB / o-ring boss. You need an o-ring for this style of fitting.
N64LR
RV-10 in progress
Old 06-18-2018, 03:07 PM
Thanks Larry,
Any idea on the fitting needed for the restricted outlet?
Trent Flemming
Hallsville, TX
Dues Paid 10/2018
Old 06-18-2018, 03:56 PM
jabarr jabarr is offline
Not sure if you're asking what fitting the blue one is, or what goes on that fitting? It could be a -3 or -4 flare (hard to tell from the pic). The end that same fitting that screws into the pump fitting is a 1/8 NPT.
Edit-- if you're measuring the blue fitting as 5/16, you need a -3 hose assy to attach to it.
Old 06-18-2018, 04:47 PM
5/16-24 UNJF is a -2 fitting, 3/8 hex.
Tom
Ridgeland, SC
Old 06-18-2018, 08:01 PM
snopercod's Avatar
I used an SAE Tee like this, only I think mine was Parker. I had a -2 AN fitting TIG welded into one of the ends and that is where I hooked up my fuel pressure sensor.
(2018 dues paid)
Old 06-18-2018, 08:30 PM
Wunderon's Avatar
Wunderon Wunderon is offline
Vanís fitting Kb90T
https://www.vansaircraft.com/cgi-bin...=pump-fittings
Dave Grimmer
RV8 firewall forward
Edmonds WA
paid 2018
Old 06-19-2018, 07:42 AM
You can make a -3 teflon hose with -2 AN on them.
Tom
Ridgeland, SC
