Old 05-30-2018, 09:12 AM
Saville's Avatar
Saville Saville is offline
Default Fuel Selector Tank Connection in Tandems
If you have a tandem seat airplane - or a side by side with the fuel selector to one side of the cabin - How do you manage the connection from the selector to the nearest tank?
In my RV-8 it's a matter of about 4"-5" from the Andair elbow to the left fuel tank fuel line fitting. The elbow on the selector and the fitting on the tank are not lined up.
Right now I have a short piece of tubing with B-nuts at each end and it's a perfect pain to get the S-shaped fuel line tube to line up so that you can start the B nuts.
There has to be a better way. Any suggestions?
Flying RV-8 N880BC
2019 Dues - happily paid.
Old 05-30-2018, 09:58 AM
YvesCH YvesCH is offline
Hi,
here is my solution to the same Problem:
(sorry upload changed it to it upside down)
FYI: As I have a Inverted pick-up in the left tank I have another bend towards the front just after passing through the hole
Cheers Yves
Yves - Basel, Switzerland
RV-8 QB #83458 in Progress
Aerosport IO-360, Catto 3 blade, G3X Touch
HB-YUA reserved
Donation 2019 done
Old 05-30-2018, 01:02 PM
Gregg---what selector valve are you using? I assume the Andair 7T valve. We use a 120* hose end in conjuction with the EF20 Andair elbow to align the hose with the side skin hole.
Tom
Ridgeland, SC
Old 05-30-2018, 01:24 PM
Saville's Avatar
Hi Tom,
Yes an Andair. I've been thinking how to use one of your flex fuel lines in this application. It would make things very simple. But I don't know about the right angle bend off the Andair elbow.
Flying RV-8 N880BC
Old 05-30-2018, 06:48 PM
The 120* hose end brings the hose back to level with the side hole.
Ridgeland, SC
Old 05-30-2018, 07:08 PM
Saville's Avatar
We need to talk. I can measure the distance from the fuselage to the fitting on the tank. Not sure about other dimensions.
By "120*" do you mean 120 degrees?
Flying RV-8 N880BC
