Brake Line To Firewall?
pilot28906
Is there a drawing that shows how the brake lines are routed from the top of the gear legs to the firewall fittings? I see C2 shows the brake line at the wheel and 36 shows at the rudder pedals. However, I can't seem to find how the solid lines are routed from the gear leg to the F.W. fittings on the RV7. I am probably missing something obvious.
Brake lines
There is no drawing that I am aware of. The general routing is down from the firewall to the lower engine mount tube then out to the gear legs with double adel clamps. It makes for a nice easy routing and it's out of the way of everything else. If you want some installation pictures send me a personal message.
As far as I know, Ryan is right. Its one of those connect the dots exercises. Various ways and routings.
Tom
