WingnutWick
Hello!
As I wrap up my panel conversion and various other mods, I have a starter question. I had previously made a push to start system where the starter wouldn't engage with the right mag on due to no impulse coupling. I'd start with the R mag off and once the motor started just turn it on.
My question is...can I just connect the R mag to the two starter switch connections so when I depress the starter button it also closes the R mag loop (grounds the mag i.e. turning it off)?
Thank you!
Wingnut
Thank you!
Wingnut
