This will be long...
Avionics/gizmo background:
GRT Sport SX EFIS, 7 years old, but latest software, with internal GPS (was an option when I bought the unit).
7 year old Trutrak autopilot.
Garmin Aera 510 GPS in airgizmos mount.
Newly installed GRT SafeFly GPS/uAvionix Echo UAT combo, connected to the Sport SX- replacing a (gasp) NavWorx EXP box.
When I built the panel, I wired it such that either the Sport SX or the Aera could feed the Trutrak autopilot a flight plan, via a toggle switch on the panel.
Originally I also fed an RS232 line from the Aera to the Sport SX so it could serve as a second GPS in the event (however unlikely) of a failure of the internal GPS.
Since the Sport SX can only support 2 GPS devices, when I installed the SafeFy GPS I disconnected the RS232 input to the Sport SX from the Aera.
Today I made a short cross country flight and engaged the autopilot for the first time since installing the SafeFly/Echo combo, and observed some very strange (to me) behaviors, which I can hopefully summarize here.
Engaging the autopilot to track a heading with the GPS input set to Aera, everything worked as expected. It turned out the winds at my altitude were negligible, so track and heading were about the same. The track displayed on the autopilot, EFIS and Aera were all the same within a degree. I tried switching the autopilot input source to EFIS; with the internal GPS (labeled as GPS 1) selected, all continued to be well. But when I tried selecting the SafeFly GPS (AKA GPS 2) as the input source, the autopilot turned the plane about 14 degrees left. Weird.
The GRT display unit maintenance page in the setup menu has a GPS status page. Checking that indicated that both the original internal GPS unit and the Safefly GPS were returning a GPS track about 14 degrees to the right of the heading displayed on the Aera. I checked ForeFlight on my iPhone, it agreed with the Aera, and even my humble magnetic compass showed the same heading. If I selected EFIS as the input source to the autopilot and selected the SafeFly GPS as the NAV option on the EFIS, the plane turned left 14 degrees. Yet, despite the internal status page indication to the contrary, selecting the old internal GPS as the NAV source returned the plane to the original correct heading. During all of this, the heading and track indications on the EFIS PFD and map pages indicated the correct (according to Aera, compass and iPhone) headings.
So for some reason both EFIS internal and external (SafeFly) GPS units appear to be reporting an erroneous 14 degrees to the right heading, but only the SafeFly GPS causes the autopilot to veer off course, and both units seem to report the correct heading information to the PFD display.
I plan to contact GRT support about this, but given the holidays I expect it will be awhile before I hear back. Meanwhile, to anyone reading, does that make sense? Happy to add clarification. This is the first I've ever heard of a GPS reading so wildly erroneously.
What thinks the collective?
