Old 03-15-2019, 05:48 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Intake filter size ?
Vanís intake will not fit in the James cowl for 0360 w/ FM-150. Don has an elbow for use with a cone filter that has significantly less area than Vans round filter. Dan H has commented on a rectangular filter area that he has used in a different config.
So, before I start developing a custom intake with optimized filter capacity, does anyone have any comment on just using Donís elbow with cone filter ?
Larry DeCamp
RV-3B flying w/ carb / Pmags / Catto 2b / Steam
RV-4 fastback w/ Superior XP360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 03-15-2019, 06:04 AM
sailvi767 sailvi767 is offline
Itís a lot to wade through and perhaps a bit off topic but there is a ton of info in this thread on intakes and filters.
G
http://www.vansairforce.com/communit...=Rocket+filter
Old 03-15-2019, 09:16 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default James
Larry,
Is there something wrong with the James intake setup?
I did 2 on carbs.....so I looked at the injected or forward facing FI setups.
Mybe the FM-150 is vertical and doesn't allow the forward facing setup?..
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 03-15-2019, 10:26 AM
airguy's Avatar
airguy airguy is offline
For vertical intakes, it might be a bit tricky. Horizontal flow works great with a K&N E-0995.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 380hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 03-15-2019, 02:44 PM
Raymo's Avatar
Raymo Raymo is online now
I did the elbow setup from Don and it works great with the SJ intake. I had to make an phenolic spacer to align the filter with the intake tube but that part also came from Don.
PM if you'd like some photos. Here's one of the in-work setup.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
