Old 03-14-2020, 06:09 PM
rapid_ascent rapid_ascent is offline
Mark,
This is great information. Thanks for you information. I suspected you had the 3/4" extension since you didn't mention adding the extension kit to alternator which would have been required for the 1.4" extension.
I guess the only question I still have is what is the difference between your RV-8 mount and my RV-7A mount in the area of the oil filter. You seem to have sufficient clearance with the 3/4" spacer I'm just not 100% sure if that would also be the case for the RV-7A mount. This is encouraging though.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 04-08-2020, 12:57 PM
I received my 0.75" oil filter spacer. I did a test mount of the 0.75" spacer and now everything looks like it should clear. I'm ready to finish up mounting the new oil filter adapter. The adapter installation instructions don't mention any type of gasket sealer. In the installation manual there is a generic reference to Gasket Maker and Gasket Sealer. So I ordered the referenced type of K&W 401504, Copper Coat Gasket Compound. I thought I should be ready to go, but looking at the originally installed gaskets it doesn't appear that this stuff was used since they look pretty clean and the Copper Coat material is this dark grayish color. The original gaskets almost look like they don't have any sealant or I guess it could be a clear sealant. So now I'm not sure of the best way to proceed.
Any comments or suggestions?
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
Old 04-09-2020, 10:37 AM
Jim Ball Jim Ball is offline
Default Oil filter adapter spacer gaskets
Hi Ray,
The gaskets do not need to have any sealant on them. Nor do they need to have oil on them. Just install them dry and torque to 96 in. lbs. We often install the B & C alternator for you when we built the engines. It is one of the many options the we offer on the Titan engines.
J.B.
James Ball (J.B.)
Continental Aerospace Technologies
2039 South Broad St.
Mobile, AL 36695
Phone 251 436 8122
jball@continental.aero
Old 04-09-2020, 02:06 PM
Thumbs up Great Titan Support
JB, thanks for all of your support. Iím afraid Iím an aircraft engine newby and its been very helpful.
JB may be cussing at the other end of the line but he never shows any side but great customer support. This is independent of how many times we go back and forth. Just great customer service.
Thanks Again.
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
