Old 01-09-2018, 10:36 PM
1flyingyogi 1flyingyogi is offline
Default AFP Fuel Pump installation help
I'm about to order the Fuel Injection kit from Airflow Performance for my RV4 and was wondering if anyone has photos that might be helpful. Specifically, I'd love to see how you mounted the electric pump. It's significantly bigger than the stock low pressure pump and I'm concerned about getting it to fit. This is probably the hardest part of the install? Any help/ tips/ photos would be greatly appreciated. Thanks!
Brian RV4 (bought)
0-320 Carbureted, FP wood prop, Raven 1/2 Oil
Dues Happily Paid
Old 01-10-2018, 06:55 AM
rleffler's Avatar
rleffler rleffler is offline
Don't you have an installation manual? Mine literally has dozens of implementation photos.
Don't be shy, give Don or Kyle a call at Airflow Performance. They are very accommodating and extremely helpful to their customers.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-10-2018, 10:15 PM
Thanks Bob. He emailed me photos, but none are of the fuel pump and none are from an RV4. They are from an RV6. I'll call him and see.
Brian RV4 (bought)
Dues Happily Paid
Old 01-11-2018, 07:06 AM
rleffler's Avatar
If you're looking for something you can copy exactly, you'll probably not have your expectations met. Use the photos to understand best practices, then take that knowledge and determine what's best for your RV-4. Even though we all start out with the same kit, no two aircraft are exactly the same.
I don't have any direct knowledge of the RV-4. Was there a electric fuel pump in any of the original plans?
Bob Leffler
Old 01-11-2018, 11:45 AM
Brian--Check your private messages-
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 01-11-2018, 06:17 PM
SJordan SJordan is offline
I put my Airflow Performance pump in the center with the stick. It's mounted on the left wall and just fits if you get Don to send you 90deg fitting for the pump. Don does not recommend using 90deg fitting but I did not want to put the pump in my forward center section and that's where my smoke tank is. PM me your email/phone and I will shot you a pic if you want one.
Shawn Jordan
KDVT
RV4. N11XZ
2018 dues paid.
Old 01-11-2018, 11:02 PM
I just PM'd you Shawn.
Bob, my stock low pressure pump is just forward of the stick, under the fuel selector valve. It looks quite a bit smaller than the AFP unit with filter, so I'm just trying to think ahead and see if anyone else was able to get it to fit in the stock location or I'll need to figure out another place for it. Once I actually have everything in front of me, it'll be much more clear.
Brian RV4 (bought)
Dues Happily Paid
