Old 01-09-2018, 01:51 PM
RyanB RyanB is offline
Default E-404 tip rib
I am busy assembling my elevators and am now instructed to attach the small E-404 tip rib to the spar, but the flange on the rib that attaches to the spar has not been bent, it just extends straight back from the rib. Is this done intentionally by Vans and if so how do you know where to bend it as the plans arenít telling me anything.
Hope this makes sense
Thanks in advance
Old 01-09-2018, 05:51 PM
chrisbryanolsen chrisbryanolsen is offline
Default Dwg 4a
Ryan,
Was recently going though this myself. If you look at Dwg 4a section B-B, towards the left of the drawing. You can see the show the flange bent up about 5/8 like the other flanges. But I think you need to adjust that to get E404 to stand proud of E403 as shown. Hope this helps
Chris Olsen
N2ZK RV-4 @ KAEG
Dues Paid Nov. 2018
Old 01-09-2018, 10:42 PM
Default Tip Rib
It certainly does thank you, so am I then correct in saying that you first installed the E403 rib and then the E404 rib?
