Old 01-06-2018, 05:07 PM
jacksel jacksel is offline
Default High CHT
I recently began flight testing my RV-7. Since my engine is new (superior XP-360) I have tried to be diligent about adhering to break-in procedure. However, from the start I have noticed that cylinders 1 and 2 (forward two) run 30 to 40 degrees warmer (CHT) than 3 and 4. I now have 13 tach hours on the engine. Is it accepted protocol in a case like mine to simply trim some off the air dams at the front?
Thank you
John Walsh
RV-7 builder
Old 01-06-2018, 05:13 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Yes. I ended up removing mine completely. Then in the winter I add some foil tape as needed, to balance the cylinders.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
1968 Mooney M20C - Sold
1956 C-182 - Sold
Old 01-06-2018, 05:22 PM
jabarr jabarr is online now
You should start with no front air dams then add as required to balance temps.
