Old 01-04-2018, 07:08 PM
Mel's Avatar
Mel Mel is offline
Originally Posted by J_Turner View Post
I read this thread today and looked up the SB's for the -7. Then I went to look at my -7 to see where all of the bolts went and to understand about the missing bolts. I then saw a few holes on the forward spar that were empty. I looked thru the instructions and plans and can't find why they are empty. Can anyone tell me what goes in these holes?(quick build BTW)
I would be very interested in knowing who certificated this aircraft. Was it a DAR or ASI? I can't imagine a DAR missing these open holes.
Never mind. Closer investigation reveals that this aircraft is not completed.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 01-04-2018, 08:04 PM
BillL BillL is offline
Thanks Capt., I found it on DWG 34. AN4-12 six places.
There are more, at least on my QB - there were 4 more but needed AN3 bolts. I could never found them on any drawing. One of the empty holes I had is filled by a rivet on yours! - -Vans told me "no empty holes" Don't look it up, just put in the proper length and diameter bolts.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Old 01-04-2018, 09:10 PM
bret's Avatar
bret bret is offline
the missing bolts for the SB go in the vertical spacer block on the R.
2018 gladly supported
Old 01-05-2018, 07:32 AM
High_Flyer's Avatar
High_Flyer High_Flyer is offline
Default Required for the RV-7
I just found it:
DWG 34 for the RV-7,
3 on top, 3 on bottom :
I'll have to verify on mine if I didn't forget them.
Build safe!
Alain.
RV7 (F-PRVZ), Tip Up, Aerosport IO-375, Dynon Skyview, VP-X, Day VFR.
Flying since June 2017.
