Old 01-01-2018, 04:23 PM
MWH265's Avatar
MWH265 MWH265 is offline
Default Need More Heat!
Happy New Year Everyone,
Flew the RV6A today in this 16 degree weather. To call the heat system inadequate is an understatement. I have a Vetterman exhaust with one heat muff, no mufflers, coming into the cabin in the toe area. Is there anything I can go to get some more heat into the cabin? I'm thinking add another muff to the other side and wrap them with an exhaust heat wrap. What is everyone else in cold climates using for cabin heat?
Mike
Old 01-01-2018, 04:38 PM
AlexPeterson's Avatar
AlexPeterson AlexPeterson is offline
Lots of things to do, all documented on this forum. Try searching for cabin heat or similar, and study away!
Alex Peterson
RV6A N66AP 1600+ hours
Maple Grove, MN
Old 01-01-2018, 05:39 PM
ralph skorupa ralph skorupa is offline
Default More Heat
I have great heat coming from my heat muff, but the big problem is that it gets out faster than it comes in. Putting "booties" on the aileron control rods helps a bunch. See Van's instructions.
Old 01-01-2018, 06:09 PM
Super Moderator
Electric seat heaters and heated motorcycle gear can be your friend this time of the year.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 01-01-2018, 06:15 PM
Plummit's Avatar
Plummit Plummit is offline
Vic
And they won't affect warm-weather ops!
-Marc
N814RV
2018 Donation made!
Old 01-01-2018, 06:16 PM
Seal the leaks. You'll have 'em at the back and sides of the slider. The leak around the aft skirt can be sealed with strips of adhesive foam. The leaks near the slider tracks can be sealed with "C" shaped strips of pipe insulation cut in half and stuffed into the gaps between the tracks and side skirts.
But, at 16F, it ain't gonna be warm. Tolerable, yes. Warm, no.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-01-2018, 06:27 PM
Pat Stewart Pat Stewart is offline
Battery powered socks
Built, RV 8, RV8A, RV 10, RV12, Purchased RV7A
Restored J3Cub and PA28R180
Pecan Plantation
Eagles Nest Mentor
EAA Tech Counselor
Old 01-01-2018, 07:16 PM
GaryK's Avatar
GaryK GaryK is offline
Default Heated seats
Seal up everything that you can and then add the seat heaters. My wife wouldn’t fly during the Michigan winters with me in the 7A if I didn’t install them. The 10 we fly now has much better heat.
I also use a heated vest in the Highlander I fly on Skis.
Gary
Old 01-01-2018, 09:20 PM
catmandu's Avatar
catmandu catmandu is offline
I had the same issue, started with my delivery flight during December a few years ago, -12*C @11.5k coming home.
Quick fix: I bought three sizes of these to cover me and my passengers, they use the same battery as my hangar drill and driver. I also use toe warmers and hand warmers.
Next, I started sealing: canopy, aileron pushrods, flap pushrods, fresh air ducting.
Then my single heat muff got stainless scrubbers inserted, a restrictor plate to limit outflow, and I just got some exhaust wrap for it that I still need to install.
I have some seat heaters I will incorporate into the cushions I plan to build up sometime this year.
Sunny days are now pretty good, cloudy days are just tolerable.
Mike C.
Maryland's Eastern Shore
stuck in 1/5th of an Arrow, my partners won't let me go
RV-6A bought flying
Old 01-01-2018, 10:27 PM
N941WR's Avatar
N941WR N941WR is offline
Before you install electric seat heaters, Google "seat warmer fire".
I'm just saying, know what you are signing up for.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
