Old 12-30-2017, 12:44 PM
rapid_ascent rapid_ascent is offline
Default Boost Pump Mounting Instructions
Does anyone know about a drawing or set of instructructions for mounting the electric fuel pump? I ordered the F-7115A/B/C parts. I'm probably not going to use the Airflow Performance fuel pump. At the moment I'm leaning towards the EFII pump but I'd still like to see how Vans planned on this section going together. I think I mostly have it figured out but I'd like to have some confirmation before I go much further.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Rolled the Fuselage
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 12-30-2017, 01:08 PM
BillL BillL is offline
OP-21 is the standard drawing for the fuel pump. It is the older one, though. I assume Vans has a new OP DWG for the latest pump. Suggest you order the digital drawing set from Vans and ask about the newest pump drawing.
I can send a print/pdf of that OP if you send your email. It may or may not help.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Old 12-30-2017, 01:22 PM
Bill,
PM sent.
Ray
Ray Tonks
2018 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
Old 12-30-2017, 01:53 PM
pilot28906 pilot28906 is offline
I'll be glad to send you a photo of mine installed if you send me your email.
John
John Johnson
Murphy, NC
RV7
Old 12-30-2017, 02:50 PM
Bill,
PM sent.
Ray
Sorry, did not get it??
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Old 12-31-2017, 10:15 AM
Ray, since Vans never intended on the EFII pump being used, they dont have ( to my knowledge) a set of plans for its installation. The ones we've done have be VARIED--to say the least! Usually in conjunction with the Andair Duplex valve for the complete EFII injection system.
But, the pump and filters can me mounted UNDER the stock covers.
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 12-31-2017, 11:41 AM
wirejock's Avatar
wirejock wirejock is offline
Default Pump install
Several photos of the Airflow Performance pump and filter on my blog. It's the pump kit Vans sells for the IO360M1B on the 7. Comes with everything except the fuel lines. I got those from TS Flightlines. Highly recommended. No need to fuss when Tom makes them perfect.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 12-31-2017, 12:46 PM
Thanks for all the comments. Bill, thanks for the Vans drawing.
I think I understand the intent. Now it's just how far I go off on my own with any modifications.
Ray Tonks
2018 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
