Old 12-28-2017, 07:22 PM
amaris amaris is offline
Default Tank and leading edge assembly issue
I'm back to the re-assembly on the wing, mounted the leading edge and now when I went to attach the tank back on, I can't get it lined up. The top side sits too far farward so I can't get the screw holes to line up. Of course, it all fit at one point before I prosealed.
I possibly could force it down with some straps but if I do that, will I ever be able to get it back on when I'm doing the final final assembly when I'm done?
The z-brackets are bolted down and the bottom side lines up okay.
I also have a few spots where the tank skin won't sit flush with the leading edge and it won't seat into the countersink holes. I thought it may have been some proseal not allowing it to sit flush with the splice, but I don't see any excess.
Any suggestions?
The top side screw holes not lining up...
The skin sitting high and won't go flush...
Allen Maris - 2017 Dues paid
Santa Ynez, CA
Old 12-28-2017, 07:40 PM
wirejock's Avatar
wirejock wirejock is offline
Default Proseal
Just a thought...Look at the Proseal bead on the aft edge of the baffle. Sometimes the bead if thick enough to touch the wing spar cap a d prevent the tank from mating. Usually it only effects the invoard end of the tank but if the bead is big, it could interfere on the spar itself. One of the tricks is to lay wax paper on the wing and actually mount the tank ( after a couple days) for a few days to allow the proseal to form.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 12-28-2017, 08:32 PM
salto salto is offline
Is it possible that you put too generous layer of proseal under the Z brackets?
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 12-28-2017, 08:51 PM
Gents, thanks for the repsonse.
Larry, there's very little proseal seeping out of the baffle, so I don't think that's it.
Salto, of course that's possible, but I spread it pretty thin on those so if it were too thick, it's not in proportion to how much the alignment is out.
Still stumped!
Santa Ynez, CA
Old 12-28-2017, 08:57 PM
Time to invoke a wooden block and a hammer. Lightly.
That was the factory recommendation 20 years ago when I had the same problem.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 12-28-2017, 09:01 PM
Carl Froehlich's Avatar
Try using 3 or so ratchet straps around the tank. You will need wood blocks against the rear spar to keep the straps from screwing up the wing skin trailing edge.
Old 12-29-2017, 11:08 AM
Carl,
I was going to do that but concerned about next time I have to put the tank back on after fitting the wings to the fuse. Does it settle into the place or will I end up having to strap it again? Which becomes more concerning when everything is in place.
Santa Ynez, CA
Old 12-29-2017, 12:08 PM
wirejock's Avatar
Default Mating wings
Originally Posted by amaris View Post
Carl,
I didn't pull the tanks to mate the wings. In fact, they haven't been removed since install.
Larry Larson
Estes Park, CO
Disclaimer
Old 12-29-2017, 12:09 PM
Carl,
Assuming you cleaned up any pro-seal that is hitting the spar (especially at the wing root) then once you strap it down it should set - or at least get better.
BTW - a two inch schotch brite wheel on an air grinder does a nice job cleaning up pro-seal from the rear baffle.
Old 12-29-2017, 12:59 PM
Thanks, that's great to know. I thought I read that it'll be coming apart again to do final assembly.
I'll double check the proseal and then give it some pressure with the straps.
Santa Ynez, CA
