Old 12-28-2017, 07:34 AM
StickNRudder StickNRudder is offline
Question Tail wheel takeoff technique for bumps
I had an unpleasant takeoff from Catalina island. I am a tail wheel noob and my normal takeoff technique is to fly the tail early so I can see. While on the roll at Catalina near rotate speed, I hit a hump in the runway which launched me in the air. I got the nose down and accelerated and continued flying but it was not pleasant (and it was my Wifeís first trip in the plane).
I am pretty sure that when the wheels hit the hump, the inertia of the tail kept it where it was with the nose rising, increasing the AOA inducing a premature lift off. The question is, what is the best technique to prevent that.
Rick Woods
N5427W == Jack, Hank, Barbara, and Rick Woods.
Flying, but not done, never done.
Old 12-28-2017, 08:04 AM
Plummit's Avatar
Plummit Plummit is offline
I don't think you did anything wrong, but you probably could have lifted off a bit earlier.
I have refused to go to AVX in my -10 - the runway was rough 3 years ago when we had our C-172 and I've heard it is in bad shape now. I would think they would take some of the $$$ they charge for landing fees and fix the runway!
-Marc
N814RV
2018 Donation made!
Old 12-28-2017, 08:15 AM
iwannarv iwannarv is offline
I fly an RV8 off a fairly rough grass airstrip. One direction on the runway there is a dip that is a guarantee to bounce you into the air. 2 up it will settle back to the ground. 1 up it might stay airborne but might not. I just keep a tailwheel low attitude no matter what it does and let the airplane fly when it's ready. I might use a little more back pressure on the stick if that will soften the bounce or release pressure to keep it in ground effect if it does want to fly, always trying to keep that similar attitude. It could be different every time.
So on overall technique, keep a set attitude, let the plane fly when it wants, fly it when it does!
Brad Brensing
RV-10 Tailcone
Old 12-28-2017, 08:33 AM
I am not familiar with this runway but knowing that it only takes a few hundred feet to get into the air in an RV gives you more options. It means that you do not have to start your roll at the end of the runway. Perhaps you could start your roll just before, or on top of the “hill” and thus avoiding the problem area. Typically it is safer to use the whole runway but sometimes it is not. Use all the advantages that the RV gives you.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
Old 12-28-2017, 11:52 AM
John Courte John Courte is offline
KPAO is interesting like that, at least it was for me last time I took off from there.
There's a low spot in the runway where your wheels leave the ground, then contact it again on the other side of the dip. If you're not ready for it, it can be a surprise. Not a big thing, I just gracelessly bounced into the air slightly ahead of schedule but it was not the slickest-feeling takeoff I've ever done.
Phase II as of 7/19/2014
http://stjohn.openbar.com/airplane
Old 12-28-2017, 02:41 PM
luddite42 luddite42 is offline
Sometimes there's not much you can do to avoid getting bounced into the air prematurely. No need to raise the tail high for takeoff, hold it tail low and accept what comes. Partial flap doesn't hurt. If you get bounced into the air before you intend to lift off, hold the stick steady just like you would for a bounce on landing. No need to significantly lower the nose, just don't let it keep coming up. It's very unlikely you'll ever get close to stalling. At full power, an extremely nose high attitude would be required to stall. Full power on stall attitude is significantly more nose high than a power off stall attitude - much steeper than the airplane sits 3-point. In addition to this, you'd need to have the stick near fully aft to stall. Go to altitude and mess with full power stalls. There is really little to fear in flying the airplane prematurely at very low airspeed (even below power off stall speed) in ground effect long enough for the airplane to accelerate to normal climb speed. Just use common sense in gusty conditions. Stall speed is also significantly reduced under full power. Just be sure to use that right rudder as needed in a high power low airspeed configuration.
Old 12-28-2017, 06:28 PM
Plummit's Avatar
Default Airnav has this to say about AVX:
Surface: asphalt, in fair condition(?)
POTHOLES AND LOOSE PAVEMENT FRAGMENTS ON RY.
- SFC ROUGH WITH NMRS POTHOLES & SOFT SPOTS.
Don't need it can't use it..... There are too many quality places to fly that don't charge landings fees and take care of their runways. I don't mind the landing fees but the conservancy needs to spend the $$$ on the airport.
~Marc
N814RV
2018 Donation made!
Old 12-28-2017, 09:49 PM
Thanks. To sum up, ride a little tail low during the takeoff roll. Would it be advisable to keep the tail wheel down completely? Seems like that might avoid the AOA increase during bumps.
As far as Catalina is concerned, I heard that there is a negotiation with the Navy right now. They want to use the field for training. Apparently, if the conservancy buys the material, the Navy will do the work. Catalina is the closest Iíll ever come to an aircraft carrier landing.
Rick Woods
Old 12-29-2017, 08:59 AM
EXflyer EXflyer is offline
Years back in a tail dragger forced the tail up a little too soon, crosswind, not much took over and almost found a row of trees after lifting off a little too soon resulted..
Old 12-29-2017, 12:10 PM
springer springer is offline
Default Learn from the expert
Charles Lindbergh had the same issue. Starts at 1:40
https://www.youtube.com/watch?v=FaGWW_TemKs
Jim
RV-4 '88-'09 Built & Sold
RV-8 Purchased
