Old 12-21-2017, 06:25 AM
rswalden's Avatar
rswalden rswalden is offline
Originally Posted by Sam Buchanan View Post
.... it remains an unknown issue as to whether or not the canopy can even be jettisoned if desired....or with what impact on the occupants...
I cut the slots for the hinges to aid construction of the tip-up canopy for the 100 times the canopy frame needs to be removed. Before paint (300 hours later) I just fiberglassed over the slots with a thin layer that could probably be kicked out if the airplane flipped over on a forced landing. My canopy release handle is just that .... another way to egress with the airplane on its back... not intended for an airborne bailout.
Bob Walden (Waldo), CFII-ASMEL
KFFC "Falcon RV Squadron" Peachtree City, GA
RV-7A Tip-Up, IO-390, 450+ Hours
RV-12 builder assist and phase 1 flight test
EAA/AOPA/Vans Air Force 2018 Supporter
Old 12-21-2017, 08:04 AM
Snowflake's Avatar
Originally Posted by rswalden View Post
...could probably be kicked out if the airplane flipped over on a forced landing. My canopy release handle is just that .... another way to egress with the airplane on its back... not intended for an airborne bailout.
When a tip-up is on its back, it sits on the canopy. Trying to kick out the hinges at that point may give you something to do, but it won't get you out of the airplane unless you can lift the entire airplane off the canopy. Unless you're floating in water and the cockpit is filled, the canopy won't open.
Rob Prior
Old 12-21-2017, 10:25 AM
Sam Buchanan's Avatar
been here awhile
For all practical purposes....the canopy jettison feature is just to make it easier to remove the canopy for major (paint?) maintenance, and the slits are not needed for that operation. I've had the canopy off my RV-6 once since 1999.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
