Old 12-18-2017, 03:30 PM
kyhunting kyhunting is offline
Default Tip Up Canopy Ejection hinge cuts
Can someone post a picture or diagram of the cuts that have to be made in the fusalage for the Tip Up canopy hinges to fit thru when the canopy ejection handle is pulled. The dimension of the cuts would be great. Thanks David
David
RV6A
O-320
Donated 11/2017
Old 12-18-2017, 09:21 PM
wjb's Avatar
wjb wjb is offline
They're just slots in the top skin above the tipup hinge ears .. as wide as the ears (plus a bit) and as deep as the ears protrude into the forward section (plus a bit) .. Enough to be able to push the canopy out once you retract the pins. This should be pretty obvious once the canopy ears are drilled and the tipper frame is in place; cut to fit.
That being said, I and other tipper builders have left this part out. There is serious debate whether we can actually eject the canopy in flight. Search the forum here for the debate.
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Avionics and FF underway!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2018 donation happily made
Old 12-19-2017, 07:54 AM
I called an acro instructor to get some training. I wanted to use my 6A. He is familiar with RV's and asked if I had the ejection handle installed and the skin cuts above the hinges. I said "No". He said that he required both in order to give the instruction in my plane. I've wanted to add the ejection handle anyway, so I will do both. It doesn't look to be detrimental to the plane. Thanks for the reply. David
David
RV6A
O-320
Donated 11/2017
Old 12-19-2017, 07:59 AM
Mel's Avatar
Mel Mel is offline
I cover the "slots" with white 3-M tape. This is the same tape that glider owners use to cover wing root joints. Just happens to match JetGlo "Matterhorn White" beautifully.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 175hp O-320, 3-Blade Catto (since 2003)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-19-2017, 08:11 AM
Mel, what width of the 3M tape? I'm gonna have to order it online. Looks like the rolls are 36 yards long and cost around $30. I guess I'll have plenty to spare... Thanks David
David
RV6A
O-320
Donated 11/2017
Old 12-19-2017, 08:30 AM
Mel's Avatar
Mel Mel is offline
It's 2" wide. Yes, it IS expensive. And Yes, one roll will last you several lifetimes!
I need to change it about every 2-3 years.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-19-2017, 08:38 AM
Sam Buchanan's Avatar
hall monitor
Could a slit cover made from 0.016" 6061 (or 0.010" aluminum roof flashing) be lightly prosealed in place and still be functional? My tip-up doesn't have the slits.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 12-19-2017, 08:41 AM
Mel's Avatar
Mel Mel is offline
I don't think I would use proseal here. Proseal is pretty tough and may not turn loose.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-19-2017, 09:42 AM
rv7charlie rv7charlie is online now
Hmmm....
Ever tried to push the tape loose, using the canopy? Ever calculated the air pressure download on the forward part (base) of the canopy at 150mph? (I haven't, but I am curious...)
On making the canopy depart: Most evidence indicates that the rear of the tipup canopy floats a few inches up when unlatched in flight. Anyone looked at how far up it would have to go to allow the hinge arms to clear the forward skin, if it *isn't* notched? There's obvious risk of getting the canopy in your face, but I suspect that risk exists, anyway.
Old 12-19-2017, 11:06 AM
hall monitor
The reason my RV-6 doesn't have the notches is I never fly with parachutes and don't plan to in the future. Since nobody has jettisoned an RV-6 canopy in flight (notches or not) it remains an unknown issue as to whether or not the canopy can even be jettisoned if desired....or with what impact on the occupants...
But we have had this discussion multiple times over the years with the same (non)conclusions.
Sam Buchanan
1999 RV-6
