Old 12-16-2017, 02:33 PM
Mort04 Mort04 is offline
Default HS-00005 and 6 attach holes.....
Unless I am blind, I canít find it in the plans where is says to match drill the holes in the forward flanges on the HS-00005 and aft flange of HS-00006 to #40. All I see is to pilot the holes to #40. After looking at other builder blogs Iíve noticed they are all drilled to #30.
Iím looking at Pg 6-2 under DRILLING THE HORIZONTAL STABILIZER bullet point 2.
Also Pg 6-3 bullet point 3,4,5
Old 12-16-2017, 03:31 PM
wirejock's Avatar
wirejock wirejock is offline
Default Blog
I don't remember an issue with drilling the holes but I always drill the smallest size first just in case. I do remember the dimension to relieve the flanges was more than necessary and actually made edge distance rather close. I rebuilt my HS after the SB and documented it. Check my blog, Empennage page, all the way at the bottom.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
