Old 12-16-2017, 02:09 PM
Turbo69bird Turbo69bird is offline
Default RV6 flap rods and bearings better way?
I feel like I rember reading that a different rod end with a through Bolt and washer was a better set up and that a different Flap push rod was also available.
my rod ends have a little play and Iíd like to replace them in the best way possible any thoughts?
i did try the search first, because I thought I remembered a thread on this but canít seem to find it.
Proud owner of 925RV
Special Thanks to Fred Stucklen
While I'm not a builder if I happen to give advice , I will not be responsible for damage to equipment, your ego, parts, world wide power outages, spontaneously generated black holes, planetary disruptions, or personal injury that may result from the use of this advice.
