Old 12-11-2017, 01:56 PM
storkeye storkeye is offline
So, I went ahead and asked Van's and their official guidance is as follows...
Trimming these at a 45 angle is perfectly acceptable and is what I would recommend you do in this case.
Sterling
I sent Van's this picture as part of my question which shows the cut marks in red...
Hope this helps.
Old 12-11-2017, 09:50 PM
Robin8er Robin8er is offline
I just put bs-319 pull rivets in and called it a day. I didn't figure out the problem until I was mostly done riveting the skin on.
RV-8
N695RA Reserved
Emp and Wings done, working on Fuselage.
Born to fly, forced to work
Old 12-18-2017, 03:57 PM
ShortSnorter ShortSnorter is offline
So, I had already riveted the top skins on before I installed the SB. What I didn't think of was riveting the aileron gap cover to the web of the main spar. I thought I was going to be able to get my bucking bar flush but the picture shows otherwise.
What's the best option here?
Ryan
RV-14 In-Progress
Build Site
Old 12-18-2017, 04:47 PM
Default RV7's sister is better
I have the RV7's sister, the RV9, and this is not a problem. The rivet is between the flanges. I will still need a thin bucking bar, but I think the RV9 will be OK. Sorry to invade the RV7 forum.
John S
Fuselage 30%
Old 12-18-2017, 05:21 PM
Originally Posted by PilotjohnS View Post
I have a the RV7 sister, the RV9, and this is not a problem. the rivet is between the flanges. I will still need a thin bucking bar, but I think the RV9 will be OK. Sorry to invade the RV7 forum.
I guess I should have mentioned this is on an RV-14.
Ryan
RV-14 In-Progress
Build Site
Old 12-19-2017, 10:19 AM
Berchmans Berchmans is offline
One rivet! leave it and build on. Some may disagree...just sayin.
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2018
Old 12-19-2017, 03:48 PM
Richard Connell Richard Connell is offline
Had the same issue on the RV-10.
You could probably leave it. I boogered mine worse than that.
Installed a cherrymax with Vans approval.
Cheers
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
