Old 11-27-2017, 05:26 PM
fbrewer fbrewer is offline
Default What RPM for Takeoff
In my RV-6, when taking off from KGTU (789' msl), I get appropriate manifold pressure of 29+ inches (depending on barometric pressure), but I only get 2340 rpm.
The motor has a fixed pitch prop.
Is this rpm appropriate for takeoff?
We have an IO360
Old 11-27-2017, 05:29 PM
Sam Buchanan's Avatar
hall monitor
Yes.
xxxxxxxxxxxxxxxxxxx
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 11-28-2017, 04:31 AM
Simon Hitchen Simon Hitchen is offline
Default Right on
I have the same engine and a Sensenich fixed pitch prop. The quoted static RPM is around 2150 which is bang on. As the speed increases and the load on the prop decreases you'll get an increase in RPM obviously.
But yeah that's right on.
Simon
Simon Hitchen
Port Perry, ON, Canada
7 Tip Up, Titan XIO-360, Sensenich FP Prop, Dynon Skyview, GTR-200, GTX-327
FLYING!
Old 11-28-2017, 07:57 AM
az_gila's Avatar
az_gila az_gila is offline
Post
Just checked one of my flights.
Carb version of O-360 with the metal Sensenich prop at 83" pitch -
2206 RPM static
2250 RPM accelerating through 25 kts on the runway during take off
MAP was around 26" with a Density Altitude of 5600 ft. at an elevation of 2940 ft.
Sensenich states that the Static RPM should be 2050 to 2250, and interestingly I've never seen a correction for static rpm for differing Density Altitudes.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-28-2017, 03:32 PM
snopercod's Avatar
I did a full-power static runup today with my fixed pitch prop and got 2,300 RPM.
(2018 dues paid)
Old 12-02-2017, 10:41 AM
Tram Tram is offline
Anyone have any numbers for an O-320? I' m seeing about 2200 static, but have told we should be seeing closer to 2350?
Old 12-02-2017, 11:40 AM
Y'all need to remember that there will be significant variation in static/takeoff rpm with various brands/pitches of fixed pitch props. 'Traditional' type fp props will have higher static if they're cut for climb, and lower if cut for cruise. Flexible props like the old Bernie Warnke 'almost constant speed' fp props will show higher static while maintaining the same cruise rpm as a 'cruise' prop, assuming same MAP.
So it's not really productive to ask someone else about their numbers, unless they have exactly the same airframe, t/o weight, engine, propeller, etc, as you.
The only really useful number to me is rpm at full throttle, leaned for best power, at ~8,000 feet, along with true airspeed at those settings. (Might not apply to the Sensenich metal f/p for 160HP, since you can't run it above 2600.)
Charlie
Old 12-02-2017, 01:00 PM
moosepileit moosepileit is offline
9:1 O-320, Vetterman crossover, mags, Carb that flows 14gph wide open in flight, 79 inch pitch 70CM6 (between cruise and climb), 2300 plus rpm once all unstalled at about 30 or so knots static std day about 800'msl.
RV-6 N91GG, bought from builder.
O-320, slider, carb, mags, FP
Old 12-16-2017, 02:02 PM
Turbo69bird Turbo69bird is offline
0320 at 195ft summer I was seeing 2150 winter Iím seeing 2240 static
Proud owner of 925RV
Special Thanks to Fred Stucklen
While I'm not a builder if I happen to give advice , I will not be responsible for damage to equipment, your ego, parts, world wide power outages, spontaneously generated black holes, planetary disruptions, or personal injury that may result from the use of this advice.
Old 12-16-2017, 02:20 PM
control control is offline
Like said, what it should be depends on choices, do you want an effective high altitude cruise prop or one giving the best take off performance... and so on.
The generic rule I tell my students: If it does not give you over 2100 during the take off roll, you should definitely suspect that something is wrong unless you have been briefed specifically about it for the AC.
RV-14 kit #140138
working on FW forward and finish kit
wings, tail kit and fuselage basically done
Http://magnusrv.blogspot.se
