Old 11-17-2017, 04:05 PM
wirejock's Avatar
wirejock wirejock is online now
Default Mounting HS
I'm prepping the fuse and HS to drill the holes for mounting. There are four holes through the HS forward spar. Two go through the longerons and two inboard. The outboard holes are dependent on edge distances. I get that.
I can't find a dimension for where the two inboard holes should be drilled. I even looked through the CD for a plan. I can't find it.
Anyone?
Any tips appreciated as well.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 11-17-2017, 04:49 PM
Bevan Bevan is offline
Hi Larry,
Look at drawing 27A. Lower right corner of the page you will find view C-C, " F-781 attach detail". It shows dimensions from the centre line.
Bevan.
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 11-17-2017, 04:51 PM
mikemalone mikemalone is offline
Someone beat me to the draw.
Mike Malone
RV7 Builder
Worcestershire, UK
Paid-Up 2018
Last edited by mikemalone : 11-17-2017 at 04:55 PM. Reason: Question already answered.
Old 11-17-2017, 05:42 PM
bret's Avatar
bret bret is offline
This is very important! measure very carful here........ekk
2018 gladly supported
Old 11-17-2017, 06:17 PM
JonJay's Avatar
JonJay JonJay is offline
One of the biggest areas for making mistakes on Edge Distances as Bret warns.
The edge distance here is the critical factor. Double check that the measurements shown layout to give you what you need on the HS angle and the longeron. Not a lot of margin here and you are drilling blind into the longeron.
I drilled a very small pilot hole then checked the underside of the longeron with a mirror to insure it was centered. While difficult once a pilot hole has been drilled, your goose isn't totally cooked yet as there are strategies to re-center the finished hole. Chances are, if you took the time to do this, all will be well because your paying attention.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 11-17-2017, 07:05 PM
RV74ME RV74ME is offline
Yep, I was about to rivet on the aft deck and was thinking ahead to this point...as I anticipated that critical drill, I looked underneath the longeron and noticed my F710B angle was a bit short....so I’m gonna redo that part and get it to nest all the way in with the longerons to prevent an edge distance issue.
Steve T.
N922WT (reserved)
KAUO (Auburn, AL)
RV-7 slow build
Tail kit COMPLETE
Wing kit COMPLETE
Fuselage kit IN PROGRESS
Old 11-17-2017, 07:12 PM
wirejock's Avatar
Default Edge distance
Thanks. Found it. Snake bit me.
Anyone else notice if the hole is perfectly centered in the longeron (5/16"), it violates the edge distance rule. Should be 3/8". No way to win.
I also made sure the F710D angle was nested against the longeron when I built it. Based on the previous, center of the longeron, edve distance there will also be 5/16" at best.
Larry Larson
Estes Park, CO
Disclaimer
Old 11-17-2017, 07:37 PM
tgmillso tgmillso is offline
Hey Larry. Not sure if you're a normal size dude or a tiny little runt like myself, but the way I did this was mark out all my edge distances and desired drilling positions on the aft deck, then drilled down first with a #30 for all four bolt locations. This ensures you get the bolt holes exactly where you want them in the longerons. I then clamped the HS in place and drilled from inside the fuselage into the HS angles, which is where being a small guy comes in handy. My hole locations turned out to be absolutely perfect.
Tom.
Old 11-21-2017, 01:37 PM
Smilin' Jack Smilin' Jack is offline
Larry,
I believe that edge distances only apply to sheet metal as discussed on this forum. That being said I believe it is critical to get the hole centered on the longerons angles. Be sure you have the rear spar supported as specified when you do all this pilot hole drilling
Jack
Smilin' Jack & Anita Hunt
N507H RV7
Jasper, Ga. KJZP
EAA690
APRS/ WB4JKY
Corporate Pilot CFI-AI, MEL
Old 11-21-2017, 03:37 PM
wirejock's Avatar
Default Supported?
Originally Posted by Smilin' Jack View Post
Larry,
Jack
I'll read the manual destructions again but I thought it had the forward holes drilled before the rear spar spacer is installed. I also called Vans and Sterling was a lot of help. He basically said get as close as possible to center on the longeron.
Larry Larson
Estes Park, CO
Disclaimer
