Go Back   VAF Forums > Model Specific > RV-4
Old 12-03-2017, 02:59 PM
Mike S Mike S is online now
Originally Posted by Dayton Murdock View Post
Paul Dye has loaned me a tool or two
Hmmmmmmmm I hear that he should have loaned you the tool that makes rectangular holes
Old 12-09-2017, 02:17 PM
Dayton Murdock's Avatar
Dayton Murdock Dayton Murdock is offline
Default Wiring
Hi All
I am still moving wires around getting ready for the auto pilot upgrade
now if I could just remember where they all went to?
Dayton Murdock
VAF#408 RV4 N359DM Flying 940 hrs. 6/1/2017
Builder Log
Old 12-09-2017, 02:48 PM
merlin3 merlin3 is offline
I have autopilot servos to install over the winter along with electric elevator trim and hopefully electric flaps. Curious to see how you mount servos
Justin
New owner of an RV-4
Old 12-10-2017, 10:16 AM
HFS HFS is offline
Default Check your PM's
Dayton -
Please check your PM's as I have a question not directly related to this thread.
Thx
David Howe
Old 12-18-2017, 11:05 AM
I have started to assemble things
This is the pitch servo
Next is the wire run, and so on
Dayton Murdock
Builder Log
Old 12-18-2017, 12:49 PM
Ironflight's Avatar
VAF Moderator / Line Boy
It's even nicer in person! Dayton does the most precise, careful, and clean installations you'd ever want to see.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-18-2017, 01:10 PM
AX-O's Avatar
AX-O AX-O is offline
Looks very familiar.............
Axel
RV-4 fastback thread and Pics
West Coast Ravens
VAF 2018 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weight out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk.
Old 12-18-2017, 10:38 PM
skylor's Avatar
skylor skylor is offline
Default Cost Neutral?
Originally Posted by rvmills View Post
...new panel = new flooring!
Bob
I thought it was new plane = new house...
Old 12-27-2017, 12:14 AM
mattsrv7 mattsrv7 is offline
Putting a plane back into Phase I often requires a letter to the local FSDO and a new test area along with a written response from the FAA (or DAR). Your operating limitations will specify what's required. Some just require a log book entry but many require more. Even if you just have a log entry, you have to have a phase 1 test area agreed with the DAR or FAA. That's super easy if you still live where the original phase 1 was done and have the paperwork.
I had to do this for an inverted oil system on my old Skybolt. The airplane had a Christen system originally that was removed. I asked the local FSDO, they said going to a Raven inverted oil system required a new 5 hour test period for the major alternation.
It took me about 6 weeks to sort the paperwork with the FAA between negotiating a new test area, getting a new set of operating limitations, and then they came out to the hangar to do the final paperwork. The folks were nice and training a new person so maybe they were more thorough than normal. A DAR likely will be quicker.
An easy link to 14 CFR Part 43 appendix A defines a major alteration
https://www.law.cornell.edu/cfr/text...x-A_to_part_43
I did the paperwork before installing the oil system to avoid down time.
Check to make sure your insurance covers Phase 1 operations.
RV-4 Bought Flying
RV-7 Tail and QB Fuselage in Progress
Old 01-02-2018, 07:29 AM
New location for the trim system relays is already paying dividends.
After testing I discovered that the elevator relay did not survive the relocation.
The old trim location has been remodeled
Dayton Murdock
Builder Log
