Old 05-17-2005, 09:33 AM
Jamie's Avatar
Jamie Jamie is offline
Originally Posted by robertahegy
Here's mine. Steam gages, KMD150, SL40, SL70, PM3000 and a mix of EI and Van's gages. Basically a nite VFR..
Roberta
Roberta:
Awesome panel. How do you like the KMD150? Also, there's a rib directly in front of the pilot behind the panel on the -7 tip-up (sorry, don't know the part# because I haven't gotten there yet!), but is your 6-pack a little off-center to deal with the rib or did you modify it? If it's off-center, does it bother you?
- Jamie, just thinking ahead here.
"What kind of man would live where there is no daring? I don't believe in taking foolish chances but nothing can be accomplished without taking any chance at all." - Charles A. Lindbergh
Jamie | RV-7A First Flight: 7/27/2007 (Sold)
Old 05-17-2005, 09:43 AM
fodrv7's Avatar
fodrv7 fodrv7 is offline
Default Pete James Console
Whoever, posted my RV-7 Panel with its' curved throttle console; thanks for the effort. I couldn't post the picture, I think because I have a Mac.
I made the console from two Canopy roll frames that I missed drilled.
If any one wants the constrcution details email me. I can also supply a Fiber glass, Kevlar or Carbon cover for the unit.
Keep riveting.
Pete.
Old 05-17-2005, 10:12 AM
RV_7A RV_7A is offline
-Pete you emailed me your panel so I posted it. Jeff
This is Dale Whittmans panel...
www.JeffsRV-7A.com
N808TX
Old 05-17-2005, 05:21 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
Thank you, Jamie!! I absolutely love the KMD150. It is the best VFR GPS I have ever used. Easy and very informative. It also can be coupled directly to autopilots (I do not have one installed) and needs no separate interface. It is short and will fit between the panel and subpanel, so you do not need to cut a through hole in the subpanel for it. That allows you to leave the canopy release mechanism intact. I just needed to cut some of the HIHAT section below the mechanism for the SL40 and SL70. And it has its own cooling fan. My SL70 and SL40 did not need the cooling fans, so I did not have to add extra cooling equipment.
The gages stradle the stock rib confirguration and seem quite normal in placement. I set the AI and DG as close the the rib as possible and mounted the others spacing them so they were all symetrical. This basically placed the AI and DG right in front.
The key to a good looking panel is just plan it out as to what you want, then lay it out so things look organized and balanced. The 6 pack concept was laid out as most gyro panels are, giving you the typical T scan configuration. I just set the major components where they were needed most and set the other less used things where room permitted. The depth and the ribs in the RV panel do pose some problems, but with planning and/or some modification, many great panels have been installed.
Hope this answers your questions,
Roberta
Old 05-17-2005, 06:11 PM
Davepar's Avatar
Davepar Davepar is offline
This is I think a fairly recent pic of Walter Tondu's panel (hope he doesn't mind me posting it for him):
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 05-18-2005, 05:59 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Whelen LED Light Man
Default RV8 Panel
Old 05-18-2005, 12:06 PM
walter's Avatar
walter walter is offline
Imagine my surprise when I'm just browsing along and I see this panel that looks very much like mine... HEY! Who copied my panel? Wait a second. LOL.
http://rv7-a.com
Close to engine start.
Old 05-18-2005, 12:12 PM
ClayR_9A's Avatar
ClayR_9A ClayR_9A is offline
Default Less is more...
Old 05-18-2005, 12:15 PM
vlittle's Avatar
vlittle vlittle is offline
Default My RV-9A Panel
http://www3.telus.net/aviation/flying/RV-9A/photos/Electrical/design_files/panel_final.jpg
I have complete layout files available in Visio as well.
http://www3.telus.net/aviation/flying/RV-9A/rv-9a
Vern Little
Old 05-18-2005, 01:24 PM
f1rocket's Avatar
f1rocket f1rocket is offline
This was the panel of my RV-6, since sold.
Randy Pflanzer
Martinsville, IN (II87)
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
