Old 04-19-2017, 02:14 AM
JurgenRoeland JurgenRoeland is offline
Default Drilling arm rests to F-704 ?
Hi,
I'm in the process of rivetting my forward fuselage and side skins to the tailcone and all excited to get to the point of rolling over the canoe.
During rivetting I noticed that I didn't drill the forward tab of the armrest F-720 into the F704 main spar bulkhead. The F704 is not predrilled at this location. I didn't do this yet because I realised the F-704K upright cap strips still needs to be put in place later. This tab in the armrest goes in with a LP4-3 pop rivet because of the impossible access on the inside later.
When did you guys actually drill this hole in the F-704 and install the pop rivet ?
Jurgen Roeland
RV7 builder Belgium
www.jursairplanefactory.com
Old 04-19-2017, 05:10 AM
tgmillso tgmillso is offline
You've got plenty of time yet. You just want to have it drilled preferably prior to painting the interior, which given that you are building a slider, should be about the last thing you do before you rivet on the F-7106 forward top skin (for access reasons). Before you get to this point make sure you have pre fitted your fuel lines, rudder bar (then removed it because you will need to get in there to buck rivets), drilled all the required holes in your firewall and mounted any doublers, put the belly insulation on (if you are doing it) and prepped the materials for the firewall insulation (but not yet installed). The arm rest should Not be riveted on until you have installed the canopy roll bar, as there is a nut holding the roll bar down on both sides that you will need to access. Once the F-704k is riveted on, you will lose access to this nut. Basically, prep/paint your arm rests and F-704K, but don't rivet them on until right at the end.
As our American cousins like to say, your mileage may vary (the metric version of that saying just doesn't seem to work).
Tom.
Old 04-19-2017, 05:38 AM
BillL BillL is offline
Default Waiting - -
Agree - during final routing of static lines & wiring, you may want to route lines/wired under that rail, having the caps off until that is completed is a good idea. Mine were installed too early and caused extra work.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Old 04-19-2017, 09:15 AM
so the K's stay of as long as possible which I was also planning.
Did you already rivet the arm rest horizontal line on the side skin and just leave the tab unattached from F704K or did you leave the whole arm rest unrivetted until last?
Jurgen Roeland
RV7 builder Belgium
Old 04-24-2017, 11:20 AM
Raymo's Avatar
Raymo Raymo is offline
Yes. Many also install a piece of aluminum angle under the arm rest to give it extra support.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 04-26-2017, 02:37 AM
thx for the response guys. building on
Jurgen Roeland
RV7 builder Belgium
Old 04-26-2017, 07:33 AM
bret's Avatar
bret bret is offline
As mentioned above I would recommend the angle reinforcement for the arm rest also. I used a router to radius the outside corner of a length of 3/4 X 3/4 .125 angle and riveted to the arm rest.
2018 gladly supported
Old 01-08-2018, 10:30 AM
Tucson_Mike Tucson_Mike is offline
Bret,
How did you attach the angle to the armrest with the fluting that was done on the armrest flange? That seems like a really good idea with how flimsy this potentially is. I haven't riveted it on yet.
Old 01-08-2018, 10:51 AM
bret's Avatar
The angle goes under the bend, not the area near the fuse skin. worked out nice.
Old 01-08-2018, 11:37 AM
wirejock's Avatar
wirejock wirejock is offline
Default J-channel
I used a piece of J-sfiffener. Fit perfect. Probably not as strong as angle.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
