Old 01-12-2018, 04:44 PM
az_gila's Avatar
az_gila az_gila is offline
Question Baggage door alarm
Presently in the UK and contemplating wiring additions for my RV-10 project when I return.
The factory has door alarms for checking the main door pins are secure and these will need lights or similar panel warning devices, so why not add a third warning light for the baggage door?
The trouble is that I could not find a good spot for a microswitch location with a completed fuselage frame.
Has anyone come up with a neat solution?
PS The wiring bundles through the cabin area were getting bigger every day.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-12-2018, 05:32 PM
leok leok is offline
Gil,
I put a micro switch in the upper rear corner. It seemed like the best location to not be seen or snagged on something going in or out of the door. I made the bracket loop around the switch to provide protection. The bracket can be lightly bent to position the switch accurately.
See the pic below for details
Building my RV-10 since Oct 5th 2014
Flying .. once I figure out how to pay for everything
http://www.mykitlog.com/leok
RV Hotel
Dues paid 2018
Old 01-12-2018, 05:48 PM
Paul from Flyleds's Avatar
Paul from Flyleds Paul from Flyleds is offline
Hi Gil
We put a microswitch inside the channel that supports the rear seat backs, which just intrudes into the space of the top left corner of the door opening. Nicely tucked away in there!
Paul McVitty
Flyleds.com
VAF advertiser
Old 01-12-2018, 06:11 PM
Gil, my $0.02----forgetaboutit.
Not putting in a warning light = less cost, less weight, less time.
Old 01-12-2018, 06:19 PM
az_gila's Avatar
Smile
I thought about that too, but if you are wiring in two for the doors adding one more is probably simpler without a magnetic reed switch involved.
The first reply looks doable but I was hoping for details on a more hidden solution.
Gil Alexander
Old 01-12-2018, 06:21 PM
az_gila's Avatar
Post
Originally Posted by Paul from Flyleds View Post
Hi Gil
I'll look at that when I get back, but that structure was already completed by the previous owner of my QB kit.
Gil Alexander
Old 01-12-2018, 10:16 PM
awmuhs's Avatar
awmuhs awmuhs is offline
Default baggage door switch
I installed mine so that when the tab that holds the door closed engages it operates a micro switch. Door closed and latched.
Alan Muhs
Tucson, Arizona
Dues overpaid December 20, 2017
RV12 Southern Arizona Teen Aviation empennage & tail cone completed
RV10 flying since July 2014- 425 hours as of Dec 2017
RV6A purchased and flying
Old 01-13-2018, 01:24 AM
az_gila's Avatar
That sounds like a great solution.
If it's OK with you I'll fly down and see it, and your Aerosport interior, when I return to Tucson.
Gil Alexander
Old 01-14-2018, 04:38 AM
awmuhs's Avatar
Default door alarm
Let me know when you want to come down
Alan Muhs
Tucson, Arizona
Old 01-14-2018, 06:12 AM
Lan Vinh Do's Avatar
Lan Vinh Do Lan Vinh Do is offline
Default door switch
I am not the builder of my rv-10 but mine have a switch that is wire with the left main door. So the left door and the bagage door have to be close to turn off my light.
Lan Vinh Do
RV-7A c-GOSV sold
RV-10 C-GMCE
Rv-7 emp completed but waiting boys to be older to help
donation 2018 done ( little bit earlyer)
