Old 01-08-2018, 07:36 PM
Glen P Glen P is offline
Default Rudder rodend bearing
The upper and mid rod end bearings are in and adjusted but I canít get the threads on the lower one to engage with the nutplate. Any ideas? Does it look like Iíve damaged the nutplate thread?
Glen Palmer
Toronto, Ontario
RV-7 empennage complete
Working on QB wings & fuselage
Dues paid July 2018
Old 01-08-2018, 07:48 PM
Super Moderator
Are you sure the hole in the spar is opened up enough?
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
YellowJacket RV9 YellowJacket RV9 is offline
Sometimes nutplates shift just enough during installation to keep a screw from properly threading into them. One thing you could do is remove the nutplate and very slightly enlarge the hole for the bolt. Or try re-installing the nutplate using a bolt threaded into it to hold it in alignment, perhaps with a new nutplate.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 01-08-2018, 07:52 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Since that's the reasonably exposed one, just remove it, enlarge the hole slightly as Vic says and put in a new nutplate.
It's not really worth screwing around with one that is proving difficult to thread.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-08-2018, 07:54 PM
bruceh's Avatar
bruceh bruceh is offline
Just run a tap in enough to get the threads started. I had to do that on one of mine. You don't want to completely tap it and loose the locking capability in the nutplate.
Bruce Hill
RV-9A N5771H flown over 600 hours!
http://www.overthehills.com/RV-9A-Project
APRS Tracking for KJ6YRP and New Flying Blog
2018 VAF donator
EAA Tech Counselor
Old 01-09-2018, 02:18 PM
Drilled out and replaced. Thanks for the advice, guys.
Glen Palmer
Toronto, Ontario
Dues paid July 2018
