Old 01-04-2018, 04:07 PM
DaleB's Avatar
DaleB DaleB is offline
Default Wheel pant repair -- how many layers?
We recently discovered a chunk missing from the rear of the wheel opening in our nose wheel pant, and a couple of trailing cracks. My guess would be a chunk of gravel or something dragged through by the tire. Anyway, I think I can clean up the cracks, epoxy them and can put a couple layers of glass over them. For the missing chunk, how many layers of cloth should I plan on? I have:
  • West Systems epoxy
  • Flox
  • Micro
  • Peel ply (Dacron fabric)
  • ACS #7520 E-glass cloth, 8.5 oz.
  • Some light weight cloth, probably 3 oz. E-glass from Spruce
I wouldn't say I've never worked with glass before, but my previous experience is probably meaningless. I would think the proper way would be to sand/grind a taper on the edges so that when I lay down the new cloth it makes a scarf joint, with an inch or two of overlap. I'm thinking the heavier 8.5 oz. cloth for everything. Am I on the right track?
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
Old 01-04-2018, 05:22 PM
BillL BillL is offline
  • Flox
  • Micro
If you follow DanH's suggestions for repair, the number of layers will be what is needed to execute the repair. You can use .011" per layer for #7520 to estimate the number to restore the original thickness. Various methods can provide a "backing" to lay the patch over after the edges are tapered. Do you already have extra layers around the perimeter of the tire opening? Restore that last.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Old 01-04-2018, 05:23 PM
DanH's Avatar
DanH DanH is offline
Yep, scarf it. Four plies is about right, or just count the existing plies when you cut the scarf.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-04-2018, 07:00 PM
DaleB's Avatar
Thanks, guys. No, there are no extra layers anywhere... pants were done per plans by the builder. I figure by the time I'm done there will be an extra layer or two all around, at least on the back half of the pant. I don't want to get too carried away.
Dale
Omaha, NE
Old 01-04-2018, 07:02 PM
This might help??
http://www.vansairforce.com/communit...ghlight=repair
Old 01-04-2018, 11:46 PM
fabricflyer fabricflyer is offline
Look in Kitplanes mag January 2018 page 36.
Allen
Old 01-05-2018, 10:29 AM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
No intention of hijacking the thread but I think this may be pertinent.
In light of the possible cause of this damage, what pant/tire clearance is the community using and are you happy with that figure?
And something that may be considered when building or rebuilding one of the wheel pants: My Cardinal wheel pants have a (16ga?). removable and adjustable steel strip at the aft end of its wheel pants, behind the tire. They refer to it as a scraper. It is curved to match the approximate curve of the tire and it must be removed to provide adequate clearance if the tire is to be removed. The service manual calls out a 1/4" to 3/8" clearance adjustment when replacing the scraper.
I considered adding this to the RV but have more than enough work just trying to get it completed. Maybe later?
Carl - - Morrison, CO
Inspection is weeks away.
Garmin fiasco is over.
paid 'til 10-19
Old 01-05-2018, 10:32 AM
DaleB's Avatar
Allen
Ha!! Perfect, thanks for pointing that out. That's exactly what I am doing, plus a couple of 6" long cracks that will be easy to fix. I found the 11/17 and 2/18 issues laying around here, but just read the article from the January issue on line. It must have gotten buried under a pile here and I missed reading it.
As a side note, Kitplanes has been far and away the best magazine I've subscribed to in years. I wish I'd done it sooner.
Dale
Omaha, NE
Old 01-05-2018, 10:38 AM
Ralph Inkster Ralph Inkster is offline
Caution to not add too many extra layers to this area & make it too strong. It's near inevitable that this area will be damaged again in the future... you don't want a small damage patch to turn into a gaping rip!
Ralph
Maintain lots, upgraded & repaired some, modified more, rebuild a few, & built 4 of 'em
