Is anyone else's throttle quadrant a magnet for engine vibrations? I feel like my engine is pretty smooth, and I had it dynamically balanced to, I believe .03 IPS.
Basically, my quadrant vibrates so much in flight that I can hear it, and it's annoying. I end up leaning my knee on it to dampen it out, but that becomes uncomfortable after a while.
I've been considering doing another dynamic balance. It was balanced prior to first flight, so maybe enough prop grease has moved around to cause a greater imbalance.
Thought I'd ask to see if others have this issue, and if there is some trick to isolating it. I thought about putting baffle seal between the quadrant and the panel, but figured the vibrations would still transfer through the attach screws.
