Does anyone have any documented pictures/method of joining two wires to a single DB pin?
I am thinking of stripping insulation back on the wire that has the pin crimped on it, then wrapping the wire around it, solder, then heat shrink- is that right? is there a recommended distance from the actual pin that is normal/standard for this?
anyone have pics??
anyone have pics??
