Old 10-21-2018, 06:41 PM
togaflyer togaflyer is offline
Default Lean of peak operation question
I did my first LOP flight from Georgia to the Florida Keys. Four hours non stop. Just want to see if my numbers are in the ball park. So here is how she ran:
Altitude was 9,500, speed at 150 true, 9.9 GPH, 58 percent, manafold at 19.8 percent, prop at 2390, CHTs between 331 and 364, EGTs between 1325 to 1360, LOP was -43 to -64 degrees. Engine felt good.
Does this sound about right.
Old 10-21-2018, 07:26 PM
Paddy's Avatar
Paddy Paddy is offline
Default CHT
Mine runs much the same. I usually bring the prop back to 2300 in LOP cruise, see about the same FF (9.5 - 10gph), a little more speed at around 160ktas. The biggest difference is CHTs, I'm used to seeing around 300 - 320deg at that altitude and WOT, could just be your higher RPM, or my northern weather. What are your temps like on the ROP side?
RV-10 N415JS
Slow build kit #40874
Homebuilt Kit Champion Oshkosh 2019
Old 10-21-2018, 07:27 PM
scsmith scsmith is offline
Default What engine do you have?
The fuel flow and power numbers depend on which engine you have, but no, I don't think your numbers sound right. In particular, your fuel flow is way too high to be LOP unless you have a bigger than typical engine. Or maybe you have an RV-10 with an IO-540? In that case your fuel flow seems better, but then why are you going so slow?
I have an IO-360 angle-valve engine. Here is what my numbers would look like at 9500 ft.
2400 RPM
MP= approx 21.0 -- 21.5 in hg something like that, WOT, of course.
170 kt true
Fuel flow 8.0--8.5 gph (depending on how far LOP I want to go)
CHT approx 290F
EGT approx 1275-1300F (again depending on how far LOP I want to go)
Now, two caveats:
1) Angle valve engines tend to run with cooler CHT because they put more heat load into the oil. I have a big cooler, so my oil temp would be 180F on a 'normal' day at this condition
2) EGT from one airplane to the next means almost nothing. It depends on where the probes are installed into the header pipes. What matters is where each cylinder temp is compared to its peak.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 550
also LS-6-15/18 sailplane
VAF donation Jan 2019
Old 10-21-2018, 07:59 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Based on the slow TAS Id guess you were too far done the LOP curve. In short, this means at that point you might be using a little less gas but power is dropping faster than fuel burn.
For 10GPH at 9500 feet you should have been over 160kts TAS. Try 15 to 20 degrees LOP, 2400rpm, WOT.
Did you balance the injectors?
Old 10-21-2018, 10:04 PM
Cannon Cannon is offline
You guys realize this is the RV-10 forum, right?
Pretty sure he’s running a IO-540, not a 360.
I’ll admit to thinking same thing until I saw what forum this post was in .
Chris
1976 C-185
1947 J3C-65
RV-8 project
Old 10-21-2018, 10:26 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
First things first. Did you use the lena find function to work out you were 43-63dFLOP? If so you were actually much leaner than that. Long story but basically, probes, algorithms and the fact when the CHT comes down it flows more air, and you will soon find that if you find peak again from the lean side, you were leaner than you thought. Lean Find functions are great concept teaching tools, but far from perfect operationally.
9500' depending on OAT would typically be a 10.5-10.7 GPH LOP setting. I get 9.9 at 13,000'
The fact your engine felt good suggests it has good F/A ratios and the GAMI spread would be 0.5GPH or less. So be happy!
Your TAS should be more like 160-164KTAS, so try getting more like 10dF LOP at that height (from the lean side) and see how you go. If the displayed TAS is not in the 160-164 range I bet you have a static source error. Then do a GPS box test. You are probably faster than you think.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 10-21-2018, 10:53 PM
Pretty sure hes running a IO-540, not a 360.
Ill admit to thinking same thing until I saw what forum this post was in .
Chris
Ah, yes, I see. My bad. When you look at "today's posts" it doesn't jump out at you which sub-forum it was posted under. I should have looked.
So your numbers look like they are in the ball park, except your speed. Check your static system as suggested
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 550
Old 10-21-2018, 11:00 PM
lr172 lr172 is offline
Originally Posted by RV10inOz View Post
the fact when the CHT comes down it flows more air, ...
I am curious about your thoughts on how CHT impacts air flow into a cylinder. I understand how higher CHTs will marginally increase the air temp in the cylinder and how hotter air is less dense and therefore requiring less fuel. However, I am stumped on how CHT impacts the actual flow of air into the cylnder.
N64LR
RV-10 in progress
Old 10-21-2018, 11:55 PM
RV10inOz's Avatar
The volumetric efficiency changes slightly.......much smarter folk like George Braly could give you specifics, but go try this for yourself. Find peak from the rich side at top of climb, get appropriately LOP, then after CHT settles then find peak from the lean side and set the same amount LOP. The FF will be higher every time.
David Brown
Old 10-22-2018, 06:02 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
I'd be interested in the reasons the VE changes with CHT as well.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 433.4 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
