Old 07-27-2018, 05:31 PM
chrispratt's Avatar
chrispratt chrispratt is offline
Super Moderator
Default GARMIN G5 UPGRADE
Finally got my Garmin G5 units installed and calibrated today – yeah! Took longer than I thought but not because of the Garmin design, just the usual retrofit/upgrade surprises you get when you need to mount new equipment and move or reroute wiring in a finished airframe.
Original Panel
With two G5 units I decided to use one as Primary Flight Display (PFD) and one as a Horizontal Situation Indictor (HSI). Mine is a standalone setup using only a GMU 11 magnetometer (no G3X system). The magnetometer is mounted in the tail, which for an RV-8 is ideal.
GMU 11 mounted on fuselage centerline, pointing forward
The G5 units mount in the holes previously occupied by my RC Allen AH and DG. I could use the same panel holes and mounting holes for the supplied G5 installation. Pretty clever how Garmin does this. Use the old mounting holes to mount a horseshoe shaped G5 mounting ring. Then insert G5 instrument and hold with an Allen screw like most radio rack mounts use.
Garmin mounts using original instrument holes
G5 Units in place
The calibration went pretty smoothly except for the Magnetometer. (Note: You do have to do the Pitch/Roll calibration separately for each G5 unit if it is a standalone installation. After that, calibrating one unit pretty much takes care of the second unit.) I placed the aircraft at the run-up area at my home field (52F), which is about the only place with enough room to do this. Pointed the aircraft to magnetic north, started the test and waited 20 minutes for something to happen. The G5 should tell you to turn right at some point but after 20 minutes -- nothing. So with all my resident “experts” away at Airventure, I decided to punt and go fly. I needed fuel so I headed to KXBP Bridgeport and after fueling saw there was no one around and a nice big ramp, so I tried the magnetometer calibration again. This time, after seven minutes, the display said, “Turn right slowly”. Eureka it was working. Once that first seven-minute test was done the remaining turns (every 30 degrees until you’re back facing North) went pretty quickly.
These are pretty cool little units. I need to figure all that they are telling me, but I’m looking forward to that over the next few weeks.
Seeing these little guys in action made the pain of crawling around the confined spaces of the fuselage worthwhile.
Happy flying,
Chris
Chris Pratt (2018 VAF DUES PAID)
RV-8 Flying, 750+ hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Aero Valley Airport, TX)
Old 07-27-2018, 07:49 PM
kentlik's Avatar
kentlik kentlik is offline
Looks really good!
Nice work!
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 07-28-2018, 06:24 AM
Brantel's Avatar
Brantel Brantel is offline
Awesome, the G5 is a great box. Hopefully I never need mine!
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 07-28-2018, 07:09 AM
chrispratt's Avatar
Super Moderator
Originally Posted by kentlik View Post
Looks really good!
Nice work!
Thank you.
Chris
N898DK
Old 08-09-2018, 08:36 AM
thompsonbr87's Avatar
thompsonbr87 thompsonbr87 is offline
I'm looking at a similar upgrade. What more would be needed to pull out the complete vacuum system?
Barrett T.
Smyrna, TN - KMQY
RV-6A
Cessna 150F (Sold)
'14 Nissan Frontier
Used bicycle from Craigslist
Weber charcoal grill
Old 08-09-2018, 09:25 AM
control control is online now
One G5 with a GMU 11 would give you all the info a 6-pack would give you.
(Two G5 if you want the full compass HSI, for VFR I would be happy with the heading band on the top of the EFIS screen)
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 08-09-2018, 01:24 PM
wnplt wnplt is offline
Time to hook up the Aera 660 to the G5 for full HSI, VNAV and CDI on PFD.
Old 08-09-2018, 02:24 PM
chrispratt's Avatar
Super Moderator
It's on my to do list.
Chris
N898DK
