Old 03-18-2018, 10:59 PM
Freebird Freebird is offline
Default Easy GPS source for ACK E-04 ELT
I recently purchased a RV-7 and spent this last week installing an ACK E-04 ELT. I was trying to figure out the best way to input a GPS source for the ELT. I did not want to break into the wiring harness for the GNS-480 at the moment, so opted for a separate GPS.
I originally looked at a Garmin 18x, but opted for a less expensive variant, the BR-355 GPS ($34 from amazon). I did not want to make a hack job of building in a 5V regulator and adapting connectors. Being that my background is in electronics, I went ahead and built a circuit board that had the same connectors. This is what I came up with.
https://drive.google.com/file/d/1GQ1...ew?usp=sharing
https://drive.google.com/file/d/133P...ew?usp=sharing
The PCB mounts to the front of the ELT. The E-04 plugs into the 4 pin DIN connector. The BR-355 gps plugs into the 6 pin DIN connector. All it needs is 8-16V power into the 9 pin Sub-D. The Sub-D connector also has the serial lines from the GPS if you want to expert that to other avionics or ADSB receivers. A built in LED allows you to trouble shoot GPS connectivity without building the harness described in ACKs manual.
With this someone could add GPS to their new or existing ACK E-04 pretty easy and cheap. Things get cheaper with higher quantity, so I was wondering anyone else would be interested in these PCBs. I would just charge the cost of components. I estimate $15-30 depending how many people (not including GPS).
-Brian
Old 08-06-2018, 11:23 PM
Snoho3 Snoho3 is offline
Brian,
Did you ever get any bites on your offer? I installed a new ACK -E04 ELT on my project and am now trying to figure out how to wire up the GPS to it. As electronics and soldering are not my thing... (Dsubs and molex connectors - no problem.) The simplicity of your seemingly plug and play concept appeals to me.
Alternatively, any suggestions for a guy who just wants to make a simple connection to the ACK provided din connector?
Snoho3
RV-9A - Tail, wings complete
QB Fuse complete
Finish Kit in work
2018 dues gladly paid
Old 08-07-2018, 02:10 AM
Cannon Cannon is offline
The sailplane guys have had this figured out for a while, though it’s more expenssive:
http://www.cumulus-soaring.com/ack.htm
Scroll down to the last item, “Cable-E04-DB9m-LED-12V-0.3”. It’s $75, but works well to connect power and a gps antenna, and it includes the LED to verify GPS data. I used the Garmin antenna they recommended, and the setup works perfectly in my Cub.
1976 C-185
1947 J3C-65
RV-8 project
Old 08-07-2018, 04:43 PM
SMO's Avatar
SMO SMO is offline
.....with the G3X EFIS I connected the serial pin #41 off the GDU465 for the signal to the Ack, pin #35 provides signal ground, pins 31 and/or 32 provide power.
Seemed pretty simple when I did it.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
Old 08-07-2018, 06:08 PM
Snoho3, I should have plenty of leftover parts. Let me look tonight. PM me your address and I will send a soldered board.
Old 08-07-2018, 08:26 PM
Awesome - will PM you. Thanks. Gotta love this forum.
Snoho3
QB Fuse complete
Finish Kit in work
