AFS 4500 Backup Battery
Chippster1
Active Member
Has anyone ou there used a 7.4v LiPo from a hobby store to backup the AFS 4500 screens? They offer much greater mAH and are a fraction of the price of the batteries offered from AFS/Dynon
Are there any down sides to doing this?
What kind of plug does the AFS use?
Ted Chipps
N498EC
If you do this, make sure your charging circuit and LiPo are happy playing with each other.
12Volts
If you were going to use a Lipo it would need to be a 3S pack which has a nominal voltage of 11.1. (Unless the 4500 uses a different back up system). I have the TCW back up boxes for my AFS 5500T's. I've had them a while and discovered they were seriously dead.
I bought replacement packs directly from TCW. I used one of my RC chargers to charge and cycle the packs a couple of times. Because of the location I mounted the boxes I decided to mount the new packs on the outside of the boxes for accessibility. They are mounted to the bottom of the boxes with industrial strength Velcro.
I opened the boxes, drilled a hole and brought the power leads and temp probe leads outside of the box. I modified the packs for a charge lead and ran wire forward to the panel area. I now have connectors under the panel to charge the packs individually. This will not affect the internal charging once the plane is up and running, but meanwhile, I can keep the packs healthy.
As Mike said, the biggest issue with a Lipo is having the appropriate charge system. I understand the newer TCW units have Lipos so a replacement would be easier and cheaper with a pack from RC sources.
