Old 06-04-2018, 06:44 PM
Super Moderator
Default Jam nuts :(
I am about ready to start a movement like Nancy Reagan's "just say No to drugs", only mine is going to say "Just say NO to loose jamnuts!"
I thought I had started a thread on this some time ago, but I can't find it right now, so you get to hear me again.
I performed a prebuy on an RV-10 today that has been flying for 8 years. So that's an Airworthiness inspection, and at least 7 Condition Inspections, and amongst the 800 hours, hopefully some preflights.
I found 7 loose jamnuts on the tail surfaces! They had never been tightened, as there was no scoring on the mating surfaces. I just reached in with my fingers and turned them.
So, please go check your jamnuts on your next preflights. This is a high stress area to begin with, with a SB even being issued across most of the models for cracking around the nutplate rivets. Perhaps someone on this forum can set up a poll that says "I have checked my aircraft jamnuts." It would be interesting to see if we could achieve 100% in the next year.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 06-04-2018, 07:10 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
The temptation might be to look at this as an issue of the jam nuts preventing the rod ends from unthreading themselves. You'd see that the angle brackets on the stabilizer prevent the rod end from turning very far, decide that the jam nuts have no particular purpose, and carry on.
However, what the jam nuts actually do is apply clamping pressure that helps transfer bending loads from the shank of the rod end into the control surface of the spar. In the absence of this clamping pressure, all that's resisting the bending loads are a couple of wimpy AN427AD3 rivets, and these rivets react the bending loads in tension. And rivets, especially when there's only one or two of them, are not all that good at reacting tension.
Once those tiny rivets break, the control surface has a lot of play to move out of plane. And that's very bad from a flutter perspective.
Bob Kuykendall
HP-24 kit sailplane
EAA Technical Counselor
Old 06-04-2018, 07:33 PM
plehrke's Avatar
plehrke plehrke is offline
Most excellent drawing to go with explanation. I have sketched many such drawings on my whiteboard to visualize what is really happening.
Philip
RV-6A - 12 years over 850 hours
Cessna 140 - 68 years over 3400 hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 06-04-2018, 07:51 PM
reminds me of a jammin song. think of this when you check your nuts.
https://youtu.be/EtTRAk7iQnA
Old 06-04-2018, 08:33 PM
j-red j-red is offline
While I’ve taken these warning to heart and check the jam nuts on every preflight, I appreciate the helpful discussion and drawings of what’s really going on. It’s always good to understand the “why.”
Rebuilt RV-6A N94CR
RV-8 In Progress
2017 Dues Paid
Old 06-04-2018, 08:42 PM
az_gila's Avatar
az_gila az_gila is offline
Question
Given that explanation, wouldn't a regular washer under the jam nut be a good idea?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-04-2018, 09:53 PM
Jesse's Avatar
Jesse Jesse is offline
Vic, I have found the same thing on several occasions. When I preflight I often check the jam nuts. Not every time, but regularly, and every time on a plane I havenít flown before.
352-427-0285
jesse@saintaviation.com
Old 06-04-2018, 09:54 PM
coffeeguy coffeeguy is offline
I do a visual on the jam nuts before every flight in my Cherokee. I don't always check them with my fingers though. It looks like it would be a good practice.
Jeff Dingbaum
RV-14A empennage, wings
Cherokee 180
2018 dues paid
Old 06-05-2018, 06:08 AM
snopercod's Avatar
On my inboard gear door - a high vibration area on takeoff - I found a loose jamb nut which allowed the rod end to partially unscrew. I didn't notice it but my tail-cam video showed that the door wasn't closing all the way. I'll be adding that to my preflight checklist.
(2018 dues paid)
Old 06-05-2018, 06:34 AM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
Default Loose nuts
Isn't everyone using a torque seal after torquing their fasteners? I would think that it's an excellent way to indicate that the fastener has been torqued and whether it has moved since then. Check and retorque at annual and reseal with a new color.
Carl - - Morrison, CO
N16CB RV7A
Airworthiness cert issued 12/24
best X-mas present I could have hoped for!
paid 'til 10-19
Closed Thread
