Old 04-04-2015, 12:17 PM
thelynns thelynns is offline
Default Kitlog multiple projects in Internet?
Hello all,
I've been using Kitlog to document my RV-7A project and have been posting the log to the internet.
Now I have a new project to rebuild a RV-6A. I would like both projects posted to the internet.
And, I may want to keep on posting to both projects.
I see I can have multiple projects in KitLog.
But, if I hit the “Post To Internet” button after editing my new RV-6A project on KitLog, what happens?
Does my original RV-7A project get replaced with the new RV-6A project?
Seems my KitLog account provides only one link to a project.
Do I have to maybe buy another KitLog account to have both posted?
If so, do I have to edit the new project on a different computer then the old project?
Thanks for any input.
Ed
Ed,
Canopy fitting, RV-7A Tipup
Rebuild project, RV-6A Slider
Old 04-04-2015, 12:35 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
You can do it. When my Kitlog file got corrupted, for a while I had two projects listed, that were actually were just the same one with two logs. Drop them an email for instructions on just how to do it.
Retired US Army Officer
Old 04-05-2015, 06:20 AM
longranger's Avatar
longranger longranger is offline
Ed,
Both projects will be posted on it KitLog. In addition to my RV-7 log, I started one to show progress on the rebuild of my C-170B. IIRC, both projects are in the same database, so you pretty much have to use the same computer for both.
Miles (VAF# 1238, Paid up as of 2018)
RV-7 TU 904KM (reserved)
Wings Fitted and Finish Kit on site
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
Old 04-05-2015, 06:39 AM
Default Multiple kitlog projects
Thanks Don, I posted the same question to support@kitlog.com. I'll report the answer to this thread when I here back from them.
Don, a hint on how multiple kitlog projects can be stored on the internet is in your kitlog link shown in your signature.
http://www.mykitlog.com/users/index....X&project=1903
I see a project number at the end of the link. You can also get to your kitlog project with the following link.
http://www.mykitlog.com/DonFromTX
Is it possible the project number at the end of your link is the registration number you enter in kitlog for each unique project? Maybe, but I'm not going to try it until I here from kitlog support. I just don't want to mess up my current project.
Hey, what have repeat offenders used to document multiple projects on the internet?
Ed
Ed,
Old 04-05-2015, 08:45 AM
flion's Avatar
flion flion is offline
You can check out my kitlog. Both RV projects are there, under their own section because both are individual projects in my database (yes, I think the key is either serial number or registration). Only thing I wish was different is that the RV-6A shows up by default from my site because it was the first one; I'd like to be able to switch that but haven't found a way.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 04-05-2015, 09:10 AM
DonFromTX's Avatar
Yep, this is an excellent example of how it works.
Old 04-07-2015, 09:48 AM
Default Multiple Projects with KitLog Pro
Thanks Patrick and Don.
Patrick, yes, your kit log is a good example of how a multiple project works with KitLog Pro.
Now mine works the same. http://www.mykitlog.com/thelynns
Two projects, very nice. You set up multiple projects on your PC running KitLog Pro. But if you want separate avatars or separate project headings you need to log into http://www.mykitlog.com and go to project preferences.
Ed,
