rcarsey
I finally got to the point where all of my wiring is done and I decided to flip the MASTER ON to see what happens A few things didn't go quite right and I'm just now beginning to double check my work. But the most obvious problem is that I popped the 30A "EMS Backup Battery". Ok something past the breaker is grounded out..
I found that the wire to the LED of the switch was hooked up to the wrong terminal. Not sure how or when it happened, but the wire on 4 should be on 8.
Just posting in case anyone else experiences the same thing.
If your top center terminal is empty, then its wrong.
