Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
  #541
Old 10-11-2017, 07:59 AM
Snowflake's Avatar
Originally Posted by geneticist View Post
But, I guess my question is what is the best way to change an active flight plan on the fly?
You can edit the active flight plan, or you can go to the flight plan list, create a new flight plan (or copy the current one to a new one), edit that, and then activate it. Even if you're part-way along the updated flight plan, the GPS will figure it out and it won't tell you to go back to the beginning and start over...
Rob Prior
Old 10-11-2017, 08:26 AM
geneticist geneticist is offline
I don't think there is a way to point and drag. I fly in the mountains pretty much exclusively, and to be able to quickly change a flight plan by drag and drop would be preferred to looking at electrical wires or other VFR waypoints (if they exist where we're flying). I have been doing it on the ipad then shooting it to the 660. As I said, the 660 has a great screen that is crystal clear and bright in all conditions.
Michael Kalchman
Old 10-20-2017, 07:28 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post Aera 660 V3.10
Good morning,
Just a heads up that Aera 660 V3.10 software may be installed today over WiFi or Webupdater.
The primary reason for the update is for our users in Australia, Asia, and Western Alaska. There is a new satellite that was turned on with visibility in that part of the world which requires us to update the GPS receiver firmware in the Aera 660, so you will see a pop-up that GPS firmware is being updated after installing this software. The affected operation area is shown in this Service Alert.
An interesting new feature, for admittedly a small, but vocal group of users, is the new Time Over Target (TOT) data field. If you are flying lead for a group that is scheduled to make a stadium or other fly-over appearance at an assigned time, you may enable display of the TOT field and adjust your speed to keep the TOT time equal to your assigned time. The TOT field works off the active waypoint, so you can either do a Direct-To your target location, or put that location in a flight plan so it becomes active after takeoff. Unlike the ETA field, the TOT field has seconds resolution to make your timing more accurate.
Changes made from version 3.00 to 3.10:
  • Add Time Over Target (TOT) data field
  • Add ability to the airport review page to pre-select chart for the active approach
  • Add ability for graphical flight plan editing when navigation is not active
  • Add message to indicate when SD card format is incompatible
  • Change map symbol for visual reporting points
  • General improvements to system operation
  • Includes update to GDL 5X software version 2.07
  • Includes update to GPS software version 3.10
  • Includes GDL 39 software version 4.80
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Last edited by g3xpert : 11-10-2017 at 10:19 AM. Reason: Added link to Service Alert
Old 10-20-2017, 10:20 AM
noelf noelf is offline
The Bandit Flight Team thanks you for the "TOT" feature.
Noel
RV-6A N6NF
tip-up
flying
Old 10-20-2017, 02:24 PM
Yobo Yobo is offline
Can you add the TOT feature to the G3X non-touch? That is a great new feature!!!!!
Kent "Yobo" Yohe
Bought Harmon Rocket
Old 10-20-2017, 05:09 PM
tangocharlie123 tangocharlie123 is offline
Default Panel Mount Wiring
How would you go about connecting the bare wire panel mount audio to a 3.5mm audio jack.
I know somewhere I have read that there is impedance issues.
I do not have an audio panel but want to feed straight into my Bose headset.
Thanks in Advance
Old 10-21-2017, 05:48 AM
gFlyer gFlyer is offline
Default 3D Vision
Steve,
Concerning to 3D vision is it possible to use the bug indicator and send a NMEA output steer command to a connected autopilot?
Would be a great feature to set a course from 3D vision page.
Best regards and thanks
gFlyer
Old 10-21-2017, 06:45 AM
olyolson's Avatar
olyolson olyolson is offline
Default Aera 660
I think I was one of those motor mouthed “vocal users” that kept bugging Steve about a TOT window. Thanks for that- a really nice feature.
For Peter in Australia- I have the audio line from the 660 wired into my Garmin GTR 200. The GTR 200 comm has a built in intercom so I get all the audio capabilities of the 660 in my headset. Probably doesn’t answer your question directly but I think if you & Steve discuss it there might be a way to go direct to the headset.
Yobo- are you jealous yet?
RV-8, Flying
Previous airplanes: RV-4, RV-3, Cessna 140, Corby Starlet, Citabria, Vari Viggen
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
Old 10-21-2017, 04:09 PM
berthoud berthoud is offline
Default Waypoint transition
The gpsmap496 allows in Route Setup to establish parameters for Waypont Transition. This allows a coupled autopilot to smoothly transition to the next leg, starting at a user-defined distance before a waypont.
I was unable to find this desirable feature in the aera660. Does it exist? If not, is it coming?
Claude
Old 10-29-2017, 06:39 AM
Originally Posted by g3xpert View Post
Good morning,
Steve
The 660 keeps getting better with each software release. The graphical Flight Plan editing is great. THANK YOU.
Can i connect my D2 BRAVO to the 660?
Michael Kalchman
